hi
using acad 18
when edit-in-place i want to add a copy of the object and not to move it.
is there a way?
You want to copy "in place" is that correct? If so start the COPY command, select the object then press the Enter key three times. You have now created a copy of the object right on top of itself.
why there is no veriable for that?
I'm sorry, I'll get right on that for the AutoCAD 2020 release.
Why should there be a variable for copying in place?
not always you want to waste the original object.
till 2020 illuse NCOPY:P
