raj banerjee Posted April 26, 2018 Posted April 26, 2018 Morning peeps, its been a while :-) I have a small problem, I have a revision block for my drawings which has info such as date, revision, drawn by, approved by etc. I have made the revision block with visual states so it can be used for a3, a2, a1 and a0 titleblocks. My question is, is there a way to make multiple attributes display the same info? So when you edit the block and input the relevent information, the information is then displayed in the correct attribute within the block with the attributes which are not needed hidden unsing the visual state option Sorry if this is unclear Quote
BIGAL Posted April 27, 2018 Posted April 27, 2018 Are you using different number of attributes for the sheet sizes not sure why your hiding attributes. Quote
