peterg Posted April 29, 2018 Posted April 29, 2018 When I have opened a drawing a text box appears in the drawing C:\Users\**********\Appdata\local\microsoft\windows\netcache\content.outlook\BSNM2NWE\drawing1.dwg how can I get rid of it? Quote
Cad64 Posted April 29, 2018 Posted April 29, 2018 Text box? Can you provide a screenshot so we can see what you mean? Also, your profile says you're using 2007. Is this correct? Here is a solution for a similar issue in 2016: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/File-name-tooltip-remains-on-top-of-all-other-Windows-in-AutoCAD.html?_ga=2.260518479.335262124.1525011526-1823013080.1510430438 Quote
SLW210 Posted April 30, 2018 Posted April 30, 2018 Sounds like some sort of path problem. Is drawing1.dwg actually open? Not sure why it would reference content.outlook. Quote
rkmcswain Posted April 30, 2018 Posted April 30, 2018 Sounds like the drawing was opened right out of Outlook, since that is the outlook temp attachment folder. Quote
