MastroLube Posted May 7, 2018 Posted May 7, 2018 Hi there, can you help me to fix this code? It doesn't work very well... I've a source dwg with 5 layers, I want to generate 4 dwg with "BORDO" and one of the other. Example: 1. BORDO + ARMAT_INF_DIR_X 2. BORDO + ARMAT_INF_DIR_Y 3. BORDO + ARMAT_SUP_DIR_X 4. BORDO + ARMAT_SUP_DIR_Y This is the code: (defun c:test (/ continue first name next_lay lay_name objects bordo) (setq continue t first t name (getvar "dwgname") name (substr name 1 (- (strlen name) 4)) name (strcat (getvar "dwgprefix") name) ) (setq bordo (ssget "X" (list (cons 8 "BORDO")))) (while continue (setq next_lay (tblnext "LAYER" first) first nil objects nil ) (setq lay_name (cdr (assoc 2 next_lay))) (if (not next_lay) (setq continue nil) (progn (setq objects (ssget "X" (list (cons 8 lay_name)))) (if (and objects (/= lay_name "BORDO")) (progn (setq lay_name (cdr (assoc 2 next_lay))) (setq objects (ssgetunion objects bordo)) (command "-wblock") (command (strcat name "_" lay_name)) (command "" (list 0 0 0)) (command objects "") (command "oops") ) ) ) ) ) (princ) ) (defun ssgetunion (sel2 sel1 /) (if sel1 (if sel2 (progn (setq ct 0) (repeat (sslength sel2) (ssadd (ssname sel2 ct) sel1) (setq ct (1+ ct)) ) ) sel1 ) (princ "\nNIL.") ) sel1 ) Looks like the last file has all the layers. I set objects to "nil" every cycle so I don't understand the reason ... Thank you! Dennis arm.dwg Quote
Lee Mac Posted May 7, 2018 Posted May 7, 2018 (edited) Consider the following code: ([color=BLUE]defun[/color] c:lay2dwg ( [color=BLUE]/[/color] bor doc dwg idx lst sel ssc sso tmp typ val ) ([color=BLUE]setq[/color] dwg ([color=BLUE]strcat[/color] ([color=BLUE]getvar[/color] 'dwgprefix) ([color=BLUE]vl-filename-base[/color] ([color=BLUE]getvar[/color] 'dwgname))) doc ([color=BLUE]vla-get-activedocument[/color] ([color=BLUE]vlax-get-acad-object[/color])) ssc ([color=BLUE]vla-get-selectionsets[/color] doc) typ ([color=BLUE]vlax-make-safearray[/color] [color=BLUE]vlax-vbinteger[/color] '(0 . 1)) val ([color=BLUE]vlax-make-safearray[/color] [color=BLUE]vlax-vbvariant[/color] '(0 . 1)) tmp 0 ) ([color=BLUE]vlax-safearray-put-element[/color] typ 0 ([color=BLUE]vlax-safearray-put-element[/color] typ 1 410) ([color=BLUE]vlax-safearray-put-element[/color] val 1 [color=MAROON]"Model"[/color]) ([color=BLUE]while[/color] ([color=BLUE]not[/color] ([color=BLUE]vl-catch-all-error-p[/color] ([color=BLUE]vl-catch-all-apply[/color] '[color=BLUE]vla-item[/color] ([color=BLUE]list[/color] ssc ([color=BLUE]strcat[/color] [color=MAROON]"lay2dwg"[/color] ([color=BLUE]itoa[/color] ([color=BLUE]setq[/color] tmp ([color=BLUE]1+[/color] tmp))))) ) ) ) ) ([color=BLUE]setq[/color] sso ([color=BLUE]vla-add[/color] ssc ([color=BLUE]strcat[/color] [color=MAROON]"lay2dwg"[/color] ([color=BLUE]itoa[/color] tmp)))) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] sel ([color=BLUE]ssget[/color] [color=MAROON]"_X"[/color] '((8 . [color=MAROON]"BORDO"[/color]) (410 . [color=MAROON]"Model"[/color])))) ([color=BLUE]progn[/color] ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] idx ([color=BLUE]sslength[/color] sel)) ([color=BLUE]setq[/color] idx ([color=BLUE]1-[/color] idx) lst ([color=BLUE]cons[/color] ([color=BLUE]vlax-ename->vla-object[/color] ([color=BLUE]ssname[/color] sel idx)) lst) ) ) ([color=BLUE]setq[/color] bor ([color=BLUE]vlax-make-variant[/color] ([color=BLUE]vlax-safearray-fill[/color] ([color=BLUE]vlax-make-safearray[/color] [color=BLUE]vlax-vbobject[/color] ([color=BLUE]cons[/color] 0 ([color=BLUE]1-[/color] ([color=BLUE]length[/color] lst)))) lst ) ) ) ) ) ([color=BLUE]vlax-for[/color] lay ([color=BLUE]vla-get-layers[/color] doc) ([color=BLUE]if[/color] ([color=BLUE]/=[/color] [color=MAROON]"BORDO"[/color] ([color=BLUE]strcase[/color] ([color=BLUE]vla-get-name[/color] lay))) ([color=BLUE]progn[/color] ([color=BLUE]vlax-safearray-put-element[/color] val 0 ([color=BLUE]vla-get-name[/color] lay)) ([color=BLUE]vla-clear[/color] sso) ([color=BLUE]vla-select[/color] sso [color=BLUE]acselectionsetall[/color] [color=BLUE]nil[/color] [color=BLUE]nil[/color] ([color=BLUE]vlax-make-variant[/color] typ) ([color=BLUE]vlax-make-variant[/color] val)) ([color=BLUE]if[/color] ([color=BLUE]<[/color] 0 ([color=BLUE]vla-get-count[/color] sso)) ([color=BLUE]progn[/color] ([color=BLUE]if[/color] bor ([color=BLUE]vla-additems[/color] sso bor)) ([color=BLUE]vla-wblock[/color] doc (LM:uniquefilename ([color=BLUE]strcat[/color] dwg [color=MAROON]"_"[/color] ([color=BLUE]vla-get-name[/color] lay) [color=MAROON]".dwg"[/color])) sso) ) ) ) ) ) ([color=BLUE]vla-delete[/color] sso) ([color=BLUE]princ[/color]) ) [color=GREEN];; Unique Filename - Lee Mac[/color] [color=GREEN];; Returns a filename suffixed with the smallest integer required for uniqueness[/color] ([color=BLUE]defun[/color] LM:uniquefilename ( fnm ) ([color=BLUE]if[/color] ([color=BLUE]findfile[/color] fnm) ([color=BLUE]apply[/color] '([color=BLUE]lambda[/color] ( pth bse ext [color=BLUE]/[/color] tmp ) ([color=BLUE]setq[/color] tmp 1) ([color=BLUE]while[/color] ([color=BLUE]findfile[/color] ([color=BLUE]setq[/color] fnm ([color=BLUE]strcat[/color] pth bse [color=MAROON]"("[/color] ([color=BLUE]itoa[/color] ([color=BLUE]setq[/color] tmp ([color=BLUE]1+[/color] tmp))) [color=MAROON]")"[/color] ext)))) ) ([color=BLUE]fnsplitl[/color] fnm) ) ) fnm ) ([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color]) Edited May 7, 2018 by Lee Mac Added (if bor (vla-additems sso bor)) Quote
MastroLube Posted May 7, 2018 Author Posted May 7, 2018 WOW thanks Lee! This code is very complex to me, I'll need a while to understand every line Thank you very much for your help Quote
Lee Mac Posted May 7, 2018 Posted May 7, 2018 WOW thanks Lee! This code is very complex to me, I'll need a while to understand every line Thank you very much for your help You're most welcome - I've tweaked the code to account for circumstances in which there are no objects on the BORDO layer. Quote
MastroLube Posted May 7, 2018 Author Posted May 7, 2018 You're most welcome - I've tweaked the code to account for circumstances in which there are no objects on the BORDO layer. Oh nice you're very kind! If I had your skills I would work half a day ahah Thank you again, see you soon ) Quote
Grrr Posted May 7, 2018 Posted May 7, 2018 If I had your skills I would work half a day ahah But you would code on the other half... And GJ Lee! Quote
MastroLube Posted May 8, 2018 Author Posted May 8, 2018 (edited) But you would code on the other half... And GJ Lee! ahah indeed!! May I ask something else? I'm looking at the code and I have few questions.. 1) Is it possible to overwrite the file instead of generate another with a different name with this function "LM:uniquefilename"? 2) Is it possible to change the file format output of write block to, for example, autocad 2009? (vla-wblock doc (LM:uniquefilename (strcat dwg "_" (vla-get-name lay) ".dwg")) sso) I've googled for this function "(vla-wblock .." but I dind't find anything. Thanks Edited May 8, 2018 by MastroLube Quote
Lee Mac Posted May 8, 2018 Posted May 8, 2018 I'm looking at the code and I have few questions..1) Is it possible to overwrite the file instead of generate another with a different name with this function "LM:uniquefilename"? Yes - change: (vla-wblock doc (LM:uniquefilename (strcat dwg "_" (vla-get-name lay) ".dwg")) sso) To: (vla-wblock doc (strcat dwg "_" (vla-get-name lay) ".dwg") sso) And remove the function definition for my LM:uniquefilename function if you wish, as this is no longer used. 2) Is it possible to change the file format output of write block to, for example, autocad 2009? (vla-wblock doc (LM:uniquefilename (strcat dwg "_" (vla-get-name lay) ".dwg")) sso) I've googled for this function "(vla-wblock .." but I dind't find anything. I may be wrong, but I'm not sure that this is possible to achieve without subsequently saving the drawing in a new format. Quote
