(setq lineset (ssget"C"pt1 pt2  '((0 . "LINE") (8 . "Layer1")))); lines on laye1
How can filter lines in layer1 and angle 90
Hi,
You need to iterate through each line entity name from the selection set then get the start and end coordinates and assign them to variable names 'p1' and 'p2' and the following codes would return T if the angle of line is equal to 90.0 Degs.
(vl-some '(lambda (ang)
           (equal ang (* pi 0.5) 1e-4)
        (list (angle p1 p2) (angle p2 p1))
Good luck.
Hi,
Good luck.
Thanks Mr. Tharwat.
Hi,
Good luck.
FWIW .. you could simplify to this:
(eq (rem angle pi) (/ pi 2.))
Nice approach ronjonp.
Cheers!! :)
Not sure whether OP wants to test for +/- pi/2 or multiples of pi/2, but for the former you could use:
(equal 0 (cos <angle>) 1e-
And for the latter:
(or (equal 0 (cos <angle>) 1e- (equal 1 (cos <angle>) 1e-)
