Some time i noticed something strange: The number that i copy (using the "Copy" tool from "Modify" toolbar, differs from the original. Here take a look at picture:
The one one the left is an orginal, and the left one is copy. The original is OK, but the copy of number 3 is some how not smooth.
This is not the first time it is happening to me. It happened several times.
What is the reason for this odd thing?
When you copied the number, did you have your Osnaps on and did you snap to another object that may not have been at Z0? This can cause what you're experiencing. Select the numbers and make sure they are both sitting at Z0.
probably you are right, because i haven`t solved the problem with lines drawed in diffrent planes (here) - this problem and that one with planes are appearing in the same drawing.
Two people answered me at that topic now, so i will have to check their post first.
