Stevery Posted May 23, 2018 Share Posted May 23, 2018 Hi all, Using AutoCAD 2018 I have created a simple Pline in image below. I want to move the left hand grip using ortho, downwards by 100. Instead of moving the grip to that point, it changes the length of the pline to 100. I was using 2017 before, and this never happened. Anyone know how to change this? Thanks Quote Link to comment Share on other sites More sharing options...
rkent Posted May 23, 2018 Share Posted May 23, 2018 I don't think you can do that with Dynmode on, turn it off and try again. Or hold F12 down to override dynmode and type 100 in while pulling the grip in the direction desired. Quote Link to comment Share on other sites More sharing options...
Stevery Posted May 23, 2018 Author Share Posted May 23, 2018 Thank you rkent, I changed the dynmode setting to 1. Quote Link to comment Share on other sites More sharing options...
danellis Posted May 24, 2018 Share Posted May 24, 2018 Try using the STRETCH command. dJE Quote Link to comment Share on other sites More sharing options...
tombu Posted May 24, 2018 Share Posted May 24, 2018 With Dynamic Mode on using 2018 and when I hover over a grip it displays options to select either Stretch or Lengthen. After selecting the grip Tab toggles between input options including the line's angle as well. Quote Link to comment Share on other sites More sharing options...
