Won't work
TunzaGibbo
Would anyone know why this line won't work?
Pt1 ang1 & dist1 are established
command line error is looking for the first point
Thank you
(command "_.line" (polar Pt1 (+ ang1 (dtr 9o)) 13) (polar ang1 dist1) "")
Where is reference point here :
(polar ??? ang1 dist1)
(dtr) sub function must be loaded, I suggest :
(dtr 90) = (cvunit 90 "degree" "radian")
BTW. Whenever you have command call that involves points input, preferable is that you specify "_non" or "_none" osnap before point spesifications...
You also have "9o" instead of "90":
(dtr 9o)
I would suggest writing your code using a font which demarcates zeroes using lines through the "0" (such as Consolas) to avoid recurrence of this mistake.
Please use a more descriptive thread title in future.
Thank you all very much for the feedback.
I must have looked at that line of code 100 times and never spotted the problem with "9o"
