lucky9
Distance between lines
lucky9
Need a lisp that would calculate distance between lines in a map and place it at the center of each lines.
I need to select all the lines at once instead of selecting each line one by one.
Regards,
lucky9
Share this post
Link to post
BIGAL
Now where is the crystal ball so I can see what you want.
Please post a dwg or image.
Share this post
Link to post
lucky9
Sample Drawing is attached for your reference..
it would be nice if the lengths are placed similar as it is shown in the drawing.
05 Key Map_Drawing_SAMPLE.dwg
Share this post
Link to post
hanhphuc
hi you should ask lisp question in
AutoLISP forum
(defun c:test (/ en d p p2 tx1 tx2)
 (setvar 'dimasz 15)
 (while (setq en (car (entsel "\nPick polyline.. ")))
   (and (wcmatch (cdr(assoc 0 (entget en))) "*LINE")
 (setq d   (vlax-curve-getdistatpoint en (vlax-curve-getendpoint en))
       p   (vlax-curve-getpointatdist en (* d 0.5))
       tx1[color="purple"] "100MM %%C"[/color]
       tx2 (strcat "L=" (rtos d 2 0) "M")
       p2  (if (and pointer:marker msg:pointer) ([color="blue"]msg:pointer[/color] (list[color="red"] (trans p 0 1)[/color]) 1 (strcat tx1 "\\P" tx2))
	     (getpoint p "\nSpecific next point.. "))
 (vl-cmdf "_leader" "_non" [color="red"](trans p 0 1)[/color] "_non" p2 "" tx1 tx2 "")
visual utility
msg:pointer
p/s: @BIGAL i noticed you were offline while the OP was online my quick reply didn't mean to hijack. :)
Edited by hanhphuc
(trans p 0 1)
Share this post
Link to post
lucky9
Hi there , I tried your solution when selecting the polyline it does nothing.
here is a screen capture.
Btw, I post the question in wrong section by mistake if any mod would move this post to the right section would be appreciated.
Share this post
Link to post
hanhphuc
did you download the visual utility link provided ?
missing routine?
pointer:marker
msg:pointer
i edited previous post, try it still can run without these visual utilities.
please retry :)
Share this post
Link to post
lucky9
missing routine?
pointer:marker
msg:pointer
please retry :)
I didn't download it ,
are you referring to msg:pointer code?
Awesome !
Share this post
Link to post
BIGAL
Hanhphuc I would use the simple check for a library routine. I like the look of the pointer code will have a closer look.8)
(if (not msg:pointer)(Load "msg-pointer")) ; save lisp as say msg-pointer
Share this post
Link to post
hanhphuc
Thanks BIGAL it makes sense, if OP keeps this sub different file :)
Share this post
Link to post
lucky9
Guys could you please elaborate more... I'm pretty basic in lisp. :D
What is visual utility and how to install it or make it to work?
Thank you ! :)
Share this post
Link to post
lucky9
Although, your solution worked pretty awesome! but what is this visual utility thingy?
Share this post
Link to post
hanhphuc
it was just my naming for those transient routines.
ACAD also has osmode, gridmode , 3dorbit & vslide etc..
example getpoint 'rubber band'
(setq [color="red"]p[/color] (getpoint ))
(setq p2 (getpoint [color="red"]p[/color]))[color="green"] ; <-- with rubberband [/color]
(setq p2 (getpoint ))[color="green"] ; <-- without rubberband you can't see startpoint [/color]
you can call any naming as you like.
Share this post
Link to post
lucky9
Thank you! hanhphuc :)
Share this post
Link to post
