samsudeenmanoos Posted June 12, 2018 Posted June 12, 2018 I tried many times to get elevation but i cannot make it please can anyone solve this? DSS.dwg[/ATTACH] Label Point.lsp Quote
hanhphuc Posted June 12, 2018 Posted June 12, 2018 (edited) (defun C:ENZ (/ ov p pt e n z) (setq ov (getvar 'cmdecho)) (setvar 'cmdecho 0) (while (and (setq p (getpoint "\nPick Point : ")) (setq pt (getpoint p "\nInsert Text : "))) (progn (mapcar '(lambda(a b) (set a (strcat (vl-princ-to-string a) "= " (rtos b 2 3)))) '(E N Z) p) (eval (vl-list* vl-cmdf "_leader" "_non" 'p "_non" 'pt "" (list E N Z "") ) ) (princ (strcat "\r" E " " N " " Z)) ) ) (if ov (setvar 'cmdecho 0)) (princ "Done!\n") (princ) ) Edited June 12, 2018 by hanhphuc previous code was incorrect if the text not placed on each vertex Quote
BIGAL Posted June 12, 2018 Posted June 12, 2018 Its a typo (setq P1Z (cadr pnt1)) ; returns Y (setq P1Z (cad[color="red"]d[/color]r pnt1)) ; returns Z also need ; [color="red"];[/color] Labeling N,E,Z Coordinates with Leader - David B. Stewart you could condense the code if you want and not use so many variables. (defun C:LP(/ pnt1 COORDN COORDE PTXT) (setq PNT1 (getpoint "\nPick coordinate point: ")) (setq COORDN (strcat "E " (rtos (car pnt1) 2 3) )) (setq COORDE (strcat "N " (rtos (cadr pnt1) 2 3) )) (setq ELEZ (strcat "EL " (rtos (caddr pnt1) 2 3) )) (setq PTXT (getpoint "\nPick text location: ")) (command "LEADER" PNT1 PTXT "" COORDN COORDE ELEZ "") (princ) ) ; even less (defun C:LP(/ ) (command "LEADER" (getpoint "\nPick coordinate point: ") (getpoint "\nPick text location: ") "" (strcat "E " (rtos (car pnt1) 2 3) ) (strcat "N " (rtos (cadr pnt1) 2 3) ) (strcat "EL " (rtos (caddr pnt1) 2 3) ) "") (princ) ) Quote
BIGAL Posted June 12, 2018 Posted June 12, 2018 (edited) Back to the dwg its 3d pline etc are you after the vertice co-ords or a 3d point along the pline. ObjectName (RO) = "AcDb3dPolyline" What I posted previously does not work with 3dpoly. Try this just need to add a bettter defun and error check ; pline co-ords example ; By Alan H ; write z of vertices added (defun getcoords (ent) (vlax-safearray->list (vlax-variant-value (vlax-get-property (setq obj (vlax-ename->vla-object ent)) "Coordinates" ) ) ) ) ; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z (defun co-ords2xy () (setq len (length co-ords)) (if (= (vla-get-ObjectName obj) "AcDb3dPolyline") (progn (setq numb (/ len 3)) (setq odd "yes") ) (progn (setq numb (/ len 2)) ; even and odd check required (setq odd "no") ) ) (setq I 0) (setq co-ordsxy '()) (repeat numb (cond ((= odd "yes") (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords)(nth (+ I 2) co-ords) ))(setq I (+ I 3))) ((= odd "no" ) (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) ))(setq I (+ I 2))) ) (setq co-ordsxy (cons xy co-ordsxy)) ) ) ; program starts here (setq co-ords (getcoords (car (entsel "\nplease pick pline")))) (co-ords2xy) ; list of 2d or 3d points making pline ; list is co-ordsxy ` (repeat (setq i(length co-ordsxy)) (setq pt (nth (setq i (- i 1)) co-ordsxy)) (setq x (car pt) ) (setq y(cadr pt) ) (if (= odd "yes") (setq z (caddr pt)) (setq z "-") ) (command "-text" (list x y) "" "" (rtos z 2 3)) ) Edited June 12, 2018 by BIGAL Quote
