You're correct.:facepalm:
The number of blocks will increase if one block contains two nested blocks. The nested blocks won't be picked until the initial block is burst
  • Replies 23
  • rlx
    10
  • Ament
    9
  • BIGAL
    2
  • dlanorh
    2
how much or what exactly do you hope to achieve with blowing up little innocent blocks? You have a couple of block definitions and a number of inserted copies. After blowing them to pieces you're left with even more pieces. Maybe better update the block definitions that are giving you trouble? Anyways , did a little test and your test drawing gets a little bit smaller.
(defun c:test ()
 (vl-load-com)
 (bang_blocks)(wipe_wipes)(wipe_blocks)(the_purge)
 (command "._qsave")
(defun bang_blocks ()
 (if (ssget "_x" '((0 . "insert")))
   (vlax-for n (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object)))
     (vla-explode n)))(princ))
(defun wipe_wipes ()
 (if (ssget "_x" '((0 . "wipeout")))
     (vla-delete n)))(princ))
(defun wipe_blocks ()
(defun the_purge ()
 (repeat 3 (vla-purgeall (vla-get-activedocument (vlax-get-acad-object)))))
@dlanorh: Of course that is the case if I have nested blocks and that is what I would expect. In this case however it bursts all blocks able to burst, and give a warning if the block is not explodeable. But when only blocks which cant be exploded are remaining it starts to insert a copy of all nonexplodeable blocks so that after a few loops you suddenly have multiple duplicates of the same block at the same locations.
@rlx: I'm using the data in another program and it creates trouble if a block is rotated, contains wipeouts or is scaled additionally I'm removing small size (
