netman Posted July 14, 2018 Posted July 14, 2018 I have had to re-install my ACLT-12 on a new computer that has Windows 10 The older one was destroyed I installed Hatch Kit http://www.hatchkit.com.au/ Created a Folder in Documents for Custom hatches Created a pattern in ACLT and Copied it to the Clipboard Pasted it from the Clipboard to Hatch Kit "new pattern" Saved it saved it to Custom Hatch Patterns in documents Created a File path in AC under File/ options Everything as should be to save and use a hatch file Opened ACLT Custom Hatch , saw the new hatch and could see a portion on the new hatch in the Swatch Window Applied new hatch It comes out BLACK every time **************************** 1. Turned "FILL" on and off Hatch turned from solid black to solid white 2. Scaled Down to 0.100 same result 3. Scaled Up to 100.00 , 1000.00 , and even 10,000.00 same solid color result 4. Drew the new pattern on the HK screen, saved it accordingly same result 5. spent two weeks on emails with HK tech guys same result Anybody have any suggestions? Quote
steven-g Posted July 15, 2018 Posted July 15, 2018 It sounds like the hatch is too dense, but we need to see a .dwg to know for sure, and also a copy of the .pat file. What I would be looking for in the first place is to see the sort of lengths used in the .pat file and the size of the area you are trying to hatch. If you see a preview then it certainly sounds like it is just a matter of scale. But descriptions of a problem and the actual cause of that problem are difficult to discover without having the actual data. Quote
SLW210 Posted July 16, 2018 Posted July 16, 2018 I would guess it's a Windows 10 and/or graphics card issue, AutoCAD LT 2012 wasn't designed for Windows 10. Does this happen with the standard hatches that came with AutoCAD? As mentioned the actual files would be nice so we don't have to take guesses. Quote
hansara Posted August 7, 2018 Posted August 7, 2018 I would guess it's a Windows 10 and/or graphics card issue, AutoCAD LT 2012 wasn't designed for Windows 10. Does this happen with the standard hatches that came with AutoCAD? As mentioned the actual files would be nice so we don't have to take guesses. I also an problem this Quote
