Edgtrimmer
LISP to rotate group of Multileaders about end of leader
Edgtrimmer
Had to rotate a floorplan 180 along with all multileaders and text. I can easily select multileaders and change angle to 0 in Properties but text ends up on top of leader or in wrong position relative to leader. It would be great to have a command able to select a group of multileaders and step through them rotating them a desired angle about the end of the leader. Any takers? Thanks!
Share this post
Link to post
Lee Mac
Try this quick one -
(defun c:rml ( / a i o s )
   (if (and (setq s (ssget "_:L" '((0 . "MULTILEADER"))))
            (setq a (getangle "\nSpecify rotation angle: "))
       (repeat (setq i (sslength s))
           (setq i (1- i)
                 o (vlax-ename->vla-object (ssname s i))
           (vla-rotate o (vlax-3D-point (mapcar '+ (vlax-invoke o 'getleaderlinevertices 0) '(0 0 0))) a)
(vl-load-com) (princ)
  • Thanks 1
Share this post
Link to post
Edgtrimmer
Wow, Lee. Thanks! It works!
Share this post
Link to post
ronjonp
           (setq i (1- i)
           (vla-rotate o (vlax-3D-point [b](mapcar '+ (vlax-invoke o 'getleaderlinevertices 0) '(0 0 0))[/b]) a)
Nice trick to grab the first point 8)
Share this post
Link to post
Grrr
Lee also did something similair here :beer:
Share this post
Link to post
Lee Mac
You're welcome :)
Thanks!
Share this post
Link to post
Shaun Wright
THANK YOU SOOOO MUCH LEE! :)
           (setq i (1- i)
Share this post
Link to post
