Devilinity Posted January 20, 2009 Posted January 20, 2009 If i got this image file of the net and i want to create a pentool line between the 2 parallel line how would i get it in the middle? for example ... ___________________________ ________________________ ___________________________ just a example, the straight line is parallel line from image and the middle red line is what i want to do, can i get it exactly in the middle or will i only be able to get it roughly near the middle? Quote
Stephen Posted February 5, 2009 Posted February 5, 2009 Could you set up guides to give you an exact measurement for the first two lines, and then place a guide at the mid-point between those two? (dividing the difference with a calculator). Maybe there's a better way, but that sort of thing works well in ID. S Quote
