raj banerjee Posted January 20, 2009 Share Posted January 20, 2009 I have a wall which is on top of another wall (ground & first floor) I can use the opening command for the ground floor and it cuts the wall nicely. If i try to do this for the wall directly above it doesnt cut the call out??? any ideas? cheers Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 20, 2009 Share Posted January 20, 2009 Really? The "opening" command? Where might I find that command? I need to check it out. Quote Link to comment Share on other sites More sharing options...
raj banerjee Posted January 20, 2009 Author Share Posted January 20, 2009 it on the mep architect workspace, or you can use the design pulldown, openings Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 20, 2009 Share Posted January 20, 2009 Thanks. For a moment I had grand visions of using a "new" command. I did not realize you are using MEP. I'm using vanilla 2009. No such command. Quote Link to comment Share on other sites More sharing options...
raj banerjee Posted January 20, 2009 Author Share Posted January 20, 2009 do you have any ideas? its oing my nut in at the moment Quote Link to comment Share on other sites More sharing options...
MaxwellEdison Posted January 20, 2009 Share Posted January 20, 2009 I use architecture and not MEP so I'm guessing here, but do you have to set the height of the openings? I know in Architecture, you have to specify a threshold height for any doors. Try finding this setting and specify your threshhold height to be the finished floor heigh of the second floor. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted January 20, 2009 Share Posted January 20, 2009 This thread has been moved to the MEP section. In the future, to avoid confusion, you should post your questions in the appropriate forum for the software you're using. Quote Link to comment Share on other sites More sharing options...
