CAD Nauseam Posted July 18, 2018 Posted July 18, 2018 Do you have a SketchUp (SKP) file you need to import into a DWG? Need to know how to do it? Tried it but it didn’t work? This tip is for you. If you’re using AutoCAD 2016 to 2019 for Windows, you can download and install the SketchUp Import plug-in from the Autodesk App Store. If that goes according to plan, this will add the command IMPORTSKP to AutoCAD. You may need to restart your AutoCAD first. It’s straightforward enough; select a file to import and it becomes a block in your drawing. Reading the reviews for this add-on, it’s … The post Importing SketchUp files into AutoCAD appeared first on cad nauseam. View the full article Quote
