auto on/off an object
i have an object or block drawn on a picture or map
i want to choose an object ,  and then for 10 times  (twice a second) , turn off and on the object , so i can compare the object with the picture below
Please advise me to improve the following code or alternate code
(defun c:onoff ()
  (setvar "cmdecho" 0)
  (setq s (ssget "_:L"))
  (while t
     (c:hideit)
     (redraw)
     (command "._delay" "300")
     (c:showit)
     (redraw)
  (c:showit)
(defun c:showit ( / i s )
    (if (setq s (ssget "_X" '((60 . 1))))
        (repeat (setq i (sslength s))
            (_substdxf 60 0 (entget (ssname s (setq i (1- i)))))
(defun c:hideit ( / i s )
    (if (setq s (ssget "_X" '((60 . 0))))
            (_substdxf 60 1 (entget (ssname s (setq i (1- i)))))
(defun _substdxf ( key value elst / pair )
    (if (setq pair (assoc key elst))
        (entmod (subst (cons key value) pair elst))
        (entmod (append elst (list (cons key value))))
i fond it 😁
(defun c:onoff (/ CurEnt CurObj CurSet)
(setq CurSet (ssget "_:L"))		;(ssget "P")
;(command "ZOOM" "OBJECT" CurSet "")
(setq CurEnt (ssname CurSet 0))
(setq CurObj (vlax-ename->vla-object CurEnt))
(repeat 6
;;; (vl-cmdf "._delay" "200")
(repeat 200000 (princ))
(vla-put-Visible CurObj :vlax-false)
(vla-put-visible CurObj :vlax-true)
);repeat
(ssdel CurEnt CurSet)
Edited by ehsantavassolian
FWIW alternative suggestion (not hiding method)
(vla-put-fade image 50)
Edited by hanhphuc
