Bobzy20
Block won't Change Colour!
Bobzy20
Hi
This 3D block doesn't wont to change colour at all, it wont allow me to go into Block Editor either.
I'm trying to put it on the block onto layer: G541-M_General lighting so it matches that layer colour.
Seems easy?
Block-Test.dwg
Edited by Bobzy20
Share this post
Link to post
rkmcswain
It's an anonymous block
Can you explode it, change the properties as needed, then make it into a regular named block? Would that work for you?
Share this post
Link to post
Cad64
I'm pretty sure it's because of the block name, *U1. Blocks with an asterisk preceding the name cannot be modified. I would explode the block and then reblock it.
Share this post
Link to post
Bobzy20
Thanks, I could do that but I have 100's more that will need changing, perhaps a script to force it would be good.
Set by layer does nothing in this case.
Share this post
Link to post
Cad64
You could do a search for a lisp routine to rename anonymous blocks. There are some out there, but I haven't used any so I can't recommend one.
Or, post a question in the Lisp section. I'm sure someone could probably write one or point you to one.
Share this post
Link to post
Jef!
Hi there. Nah, for entities inside a block, if you want them to be of the color of the layer on which the block is inserted, the entities need to be "byblock"!
Here's a snippet that will modify all blocks named *U* and put everything inside by block. It might have unwanted effects if you have other *u blocks that you don'T want to handle like that (like modified dyn blocks). It also doesn'T go inside nested blocks, but it works fine on your drawing sample.
(defun c:ufix ( / acdoc regen)
  (vlax-for blk (vla-get-Blocks (setq acdoc (vla-get-ActiveDocument (vlax-get-acad-object))))
    (if (wcmatch (vlax-get-property blk 'name) "`*U*")
      (vlax-for ent blk
        (if (and (vlax-property-available-p ent 'color T)
                 (not (= 0 (vlax-get-property ent 'color)))
              (vlax-put-property ent 'color 0)
              (setq regen T)
  (if regen (vla-regen acdoc acAllViewports))
Try it and let me know how it works for you
Cheers
Share this post
Link to post
