Hi
This 3D block doesn't wont to change colour at all, it wont allow me to go into Block Editor either.
I'm trying to put it on the block onto layer: G541-M_General lighting so it matches that layer colour.
Seems easy?
Block-Test.dwg
Edited by Bobzy20
It's an anonymous block.
Can you explode it, change the properties as needed, then make it into a regular named block? Would that work for you?
I'm pretty sure it's because of the block name, *U1. Blocks with an asterisk preceding the name cannot be modified. I would explode the block and then reblock it.
Thanks, I could do that but I have 100's more that will need changing, perhaps a script to force it would be good.
Set by layer does nothing in this case.
You could do a search for a lisp routine to rename anonymous blocks. There are some out there, but I haven't used any so I can't recommend one.
Or, post a question in the Lisp section. I'm sure someone could probably write one or point you to one.
Hi there. Nah, for entities inside a block, if you want them to be of the color of the layer on which the block is inserted, the entities need to be "byblock"!
Here's a snippet that will modify all blocks named *U* and put everything inside by block. It might have unwanted effects if you have other *u blocks that you don'T want to handle like that (like modified dyn blocks). It also doesn'T go inside nested blocks, but it works fine on your drawing sample.
(defun c:ufix ( / acdoc regen)
  (vlax-for blk (vla-get-Blocks (setq acdoc (vla-get-ActiveDocument (vlax-get-acad-object))))
    (if (wcmatch (vlax-get-property blk 'name) "`*U*")
      (vlax-for ent blk
        (if (and (vlax-property-available-p ent 'color T)
                 (not (= 0 (vlax-get-property ent 'color)))
              (vlax-put-property ent 'color 0)
              (setq regen T)
  (if regen (vla-regen acdoc acAllViewports))
Try it and let me know how it works for you
Cheers
