Create Multileader with default text using lisp
Hi. Please help me with this code, i'm stuck with it, the mleader cant get content from filtboxlist (Lee Mac) :
(defun c:demo (/ ans)
  (setq ans (LM:filtlistbox "Pick up a contents"
                      "Item1"
                      "Item2"
                    60
                    20
  (command "_mleader" pause pause ans)
) ; end_defun
;; Filtered List Box  -  Lee Mac
;; Displays a list box interface from which the user may select one or more items.
;; Includes an edit box filter to enable the user to filter the displayed list of items.
;; msg - [str] List box dialog title
;; lst - [lst] List of strings to display in the list box
;; mtp - [bol] T=Allow multiple items; nil=Single item selection
;; Returns: [lst] List of selected items, else nil
(defun LM:filtlistbox ( msg lst mtp / _addlist dch dcl des rtn sel tmp )
    (defun _addlist ( key lst )
        (start_list key)
        (foreach x lst (add_list x))
        (end_list)
        lst
    (if
        (and
            (setq dcl (vl-filename-mktemp nil nil ".dcl"))
            (setq des (open dcl "w"))
            (write-line
                (strcat
                    "filtlistbox : dialog { label = \"" msg "\"; spacer;"
                    ": list_box { key = \"lst\"; width = 50; fixed_width = true; height = 15; fixed_height = true; allow_accept = true; "
                    "multiple_select = " (if mtp "true" "false") "; }"
                    ": edit_box { key = \"flt\"; width = 50; fixed_width = true; label = \"Filter:\"; }"
                    "spacer; ok_cancel; }"
                des
            (not (close des))
            (< 0 (setq dch (load_dialog dcl)))
            (new_dialog "filtlistbox" dch)
            (_addlist "lst" (setq tmp lst))
            (set_tile "lst" (setq rtn "0"))
            (set_tile "flt" "*")
            (action_tile "lst" "(setq rtn $value)")
            (action_tile "flt"
                (vl-prin1-to-string
                   '(progn
                        (setq flt (strcat "*" (strcase $value) "*")
                              sel (mapcar '(lambda ( n ) (nth n tmp)) (read (strcat "(" rtn ")")))
                        (_addlist "lst" (setq tmp (vl-remove-if-not '(lambda ( x ) (wcmatch (strcase x) flt)) lst)))
                        (set_tile "lst"
                            (setq rtn
                                (vl-string-trim "()"
                                    (vl-princ-to-string
                                        (cond
                                            (   (vl-sort (vl-remove nil (mapcar '(lambda ( x ) (vl-position x tmp)) sel)) '<))
                                            (  '(0)   )
            (setq rtn
                (if (= 1 (start_dialog))
                    (mapcar '(lambda ( x ) (nth x tmp)) (read (strcat "(" rtn ")")))
    (if (< 0 dch)
        (setq dch (unload_dialog dch))
    (if (and (= 'str (type dcl)) (findfile dcl))
        (vl-file-delete dcl)
    rtn
http://www.lee-mac.com/filtlistbox.html
If you read the example in this link carefully, the snippet requires 3 arguments.
If you want to insert numeric values into item1 and item2,
you will have to create 1 list and then extract it,
or just hard coding it and process it with the (cond) statement.
Hi, I’m new to Lisp programming. Could you help me in a more detailed way?
                      "60"
                      "20"
                    nil
  (command "_mleader" pause pause (car ans))
) ; end_defun
I don't know what you want to put in mleader just by looking at the code, but I guessed that you wanted to put 60 or 20, and changed it like this.
                      "60"
                      "20"
                    nil
) ; end_defun
sorry, I’m going to insert some text into mleader from filtlistbox, for example: “content1” and “content2”....
                      "Content1"
                      "Content2"
                      "Almost heaven"
                      "West Virginia"
                      "Blue Ridge Mountains"
                      "Shenandoah River"
                    nil
) ; end_defun
It's as simple as just changing the value between " and " to the value you want.
  • Thanks 1
                      "Content1"
                      "Content2"
                      "Almost heaven"
                      "West Virginia"
                      "Shenandoah River"
                    nil
) ; end_defun
Thanks so much for your help, you save me a lot !!
  • 1 year later...
I tried this but I'm running into an issue where no matter what I always get prompted the MText Box at the end! any ideas how to by pass this? Is there a global variable that needs to be set or a style setting?
(defun c:demo ( / ml_txt)
  (setq ml_txt "Aluminium")
  (command "_mleader" pause pause ml_txt)
after re-setting autocad to factory default it works again ...this means I mus have inadvertently change some AutoCAD global variable that affects the leader creation. (would love to know what it is so I can force it before issuing the command).
Thanks for the tip... I'll look into it.
I create a common save and reset functions which a call at the beginning and end of every LISP routine and also reset inside error handler and I add to as I need to..
; Set Global variable on load. ---------------------------
(setq g_attdia (getvar 'attdia))
;Smaple Lisp ---------------------------------------------
(defun c:foo()
	(c:savesettings)
  ;Change Settings as need
  (setvar 'attdia 1)
  ;Catch errors and re-set settings.
  (defun *error* ( msg )
    (if (not (member msg '("Function cancelled" "quit / exit abort")))
    (c:resetsettings)
	;Add new Code Here
	(princ "\nAdd my code here")
	(c:resetsettings)
;Store inital settings ------------------------------------
(defun c:savesettings ()
  (princ "\nSave settings..")
;Restore settings ----------------------------------------
(defun c:resetsettings ()
  (princ "\n...Reset settings")
	(Setvar "ATTDIA"  g_attdia)
  • 2 months later...
