criehle Posted January 20, 2009 Share Posted January 20, 2009 I know you can edit ESRI shapfiles in AutoCAD Map but can you edit Feature classes located in a Geodatabase? We have a file based geodatabase and I want to be able to edit those feature classes in AutoCAD just like you can do with a shapefile. I tried connected to the data using the ArcSDE connection and that doesn't work because we don't have an ArcSDE Geodatabase. We have a file Geodatabase. Quote Link to comment Share on other sites More sharing options...
