criehle Posted January 20, 2009 Posted January 20, 2009 Sometimes I zoom in using the roller and the program will not allow me to zoom back out even though there is more of the drawing to show. Sometimes zoom to extent does not even work Why does it do this? I'm using AutoCAD Map 2009 Quote
hay123 Posted January 21, 2009 Posted January 21, 2009 Hi, I am using Map 3d 2009 also, but have not encountered any zooming issues. May not be very useful, but perhaps next time you can't zoom back with mouse try zoom via toolbar or keyboard command. Could point to a problem with mouse. Zoom extents not working seems odd though. Does it do a partial zoom? or nothing at all?, maybe there is a dockable window not fully docked, but floting on workspace, and inhibiting full view of your workspace. Quote
kool130 Posted January 22, 2009 Posted January 22, 2009 I got the same problem sometimes and i fix it using this LSP.. (defun c:ww(/ p1 x) (setvar "cmdecho" 0) (prompt "\nZoomOut") (setq p1 (getpoint "\nCenter to ZoomOut? ")) (setq x "y") (while x (command "zoom" "c" p1 ".5x") (setq p1 (getpoint "\nCenter to ZoomOut? ")) (if (= p1 nil) (setq x nil))) (princ)) ------ peace out Quote
manhattan Posted January 22, 2009 Posted January 22, 2009 this happens to me regularly. as rgarjr said a regen should sort it Quote
merdrignac Posted January 22, 2009 Posted January 22, 2009 Could try re-setting the drawing limits or turning them off, then regen all. Quote
