Ixoye Posted October 8, 2018 Share Posted October 8, 2018 (edited) Hello all, I have a block, (Data Block), which is a listing of data followed by a leader that is pointing to multiple Mechanical Parts in the drawing. Each Part will have it's own (Data Block) but different technical data. I need to create a Lisp routine that would in-able me to insert this block several times and renaming each to match the Part. Do I have to insert the block, explode, make new block, rename it and then reinsert the old block to a new Part and start the process over again several times? What I would like to do is to insert this block for the first Part and rename it as "..."#1, the second Part as "..."#2, etc. Edited October 8, 2018 by Ixoye Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 8, 2018 Share Posted October 8, 2018 Sounds like you're describing my Copy/Rename Block Reference application. Quote Link to comment Share on other sites More sharing options...
