Kai Hern 0 Posted October 25, 2018 Hey guys, may i know is it possible to let the dimension of the main assembly changed after main assembly was pack and go into different folder when i changed the dimension in the ' pack and go ' folder? Quote Share this post Link to post Share on other sites
stevsmith 12 Posted October 31, 2018 When you pack and go it breaks the reference links from the original model. So, if you were to modify the pack'n'go file, it should not alter the original file. During the pack and go process you should change the filename as to differentiate between the two variants. Quote Share this post Link to post Share on other sites
