Removing Leading Numbers from Elevation
ktbjx
How do I remove leading Number after the decimal point from LINE elevation?
(defun c:test (/ ss obj elev lay)
(setq ss (ssget (list (cons 0 "LINE"))))
   (setq obj (ssname ss (setq x (- x 1))))
   (setq elev (caddr (cdr (assoc 10 (entget obj)))))
   (setq lay (rtos elev 2 1))
   (command "-layer" "m" lay "")
   (command "._change" obj "" "p" "la" lay "")
Im so stupid, I know >.<"
Edited by ktbjx
So you want 0.1 to be .1 ? You convert to a string above code Lay = "0.1" , check 1st character if 0 then remove using "substr" and "strlen" function. Very easy.
Edited by BIGAL
im sorry, I made a mistake about my question,
I want to remove all numbers after the decimal point.
so for your example
0.1 would be 0
1.4000 will be 1
698.345 will be 698
just remove all numbers after decimal
so for your example
0.1 would be 0
1.4000 will be 1
698.345 will be 698
1.55 → 1 or 1.55 → 2 ?
Edited by Lee Mac
2 hours ago, Grrr said:
Neat trick, Lee! :thumbsup:
(mapcar
  '(lambda (x) (fix (+ 1e-8 x)))
  '(2.1 2.9 3.14 0.15)
>> (2 2 3 0)
Thanks - of course, fix on its own would yield the same -
_$ (mapcar 'fix '(2.1 2.9 3.14 0.15))
(2 2 3 0)
But the inclusion of the 1e-8 'fuzz' accounts for rounding of doubles and avoids situations like this:
_$ (fix (- 8.2 0.2))
7
Though, when used in practice, one should really account for the possibility of negatives since:
_$ (fix (+ -2 1e-8))
-1
And so, perhaps a better suggestion would be:
(setq lay (itoa (fix ((if (minusp elev) - +) elev 1e-8))))
Edited by Lee Mac
