Jim Clayton Posted October 30, 2018 Posted October 30, 2018 So I'm not entirely sure if my question is pertaining to Visibility States or Lookup Tables. I have some Flange blocks like the attached and if you click on the Visibility drop down you'll see that the list is huge. I'm wanting to take that single long list and have two drop downs...one for Size (inches) and one for Rating/Class. Basically the user would select the Size in inches first with one Visibility menu, then the Class/Rating with another Visibility menu. I can't figure out how to do this or if it's possible but I feel like I've come across dynamic blocks like this before. If anyone has any knowledge on this, I'd greatly appreciate it. Tks. Dynamic HH Flange.dwg Quote
maratovich Posted October 31, 2018 Posted October 31, 2018 Visibility parameter .... hard question ... May be : Create two visibility parameters. One parameter shows all blocks with size selection. The second parameter selects depending on the class. Quote
Jim Clayton Posted October 31, 2018 Author Posted October 31, 2018 Well that was my initial thought but for whatever reason I haven't been able to achieve it. I'm by no means a Dynamic Block expert though. Is there something specific that I have to do in order to make it work? And thanks for the reply. Quote
maratovich Posted November 1, 2018 Posted November 1, 2018 Multiple visibility - no standard feature. It is necessary to do it by hand. Check out this, there you can create a lot of visibility. Online translation to English is required : Creation of additional parameters Visibility Set in dynamic blocks. Quote
