Hello...I have been looking for a long time, but since I have not found anything yet, I ask you the following problem.
There is a lot of lisp to realize a numerical sequence with prefixes, suffixes and variable part and that allow to increase the texts or the attributes...some are well made and I use them too...but...
Is it possible simplify everything by increasing a single digit of a selected attribute? (for example the last one)
For example I select an attribute with value 15.QF5 and I wanto to change in 15.QF6
greetings in the meantime
Hi, heres a subfunction to increment the last numerical character(digit) in the string:
(setq tmp "15.QF5")
(repeat 12 (print (setq tmp (lastchr++ tmp))))
"15.QF6"
"15.QF7"
"15.QF8"
"15.QF9"
"15.QF0"
"15.QF1"
"15.QF2"
"15.QF3"
"15.QF4"
"15.QF5"
"15.QF6"
"15.QF7"
(setq lastchr++
  (lambda (s)
      (lambda (L)
        (vl-list->string
          (reverse
            (cons
              (cond ( (cadr (member (car L) (append '(48 49 50 51 52 53 54 55 56 57 48)))) ) ( (car L) ) )
              (cdr L)
      (reverse (vl-string->list s))
Something I was working on solves the problem of when 15.gh10 should go to to 15.gh11, you look at the last character if a number do ok look at next working right to left is it a number and so on so 1 12 123 will work so convert the end numbers to be just that add 1 then update string.
Its at work and I am not there, Lee-Mac has a parse number it may be possible to reverse engineer it. The question lends itself to 2 library routines get number suffix or prefix. May not get a chance today it’s a lambda function needed. Is it between 1-0.
I'm not sure if you have something like this,
(defun c:uprev( / anumber ones tens hundreds thousands revisionprefix leadingzero)
;;increases a revision code / text string to the next value
(princ "\n")
;;select revision code
  (setq ent (car (nentsel "\nSelect Revision Letter:")))
  (setq entlst (entget ent))
  (setq currentrevision (cdr (assoc 1 entlst)))
  (setq revlength (strlen currentrevision)) ;;length of selected revision
  (setq revisionprefix "")
  (setq anumber 0)
  (if (< 0 revlength)(progn
      (setq ones (substr currentrevision revlength))
      (if (numberp (read ones))(setq anumber 1))
  (if (< 1 revlength)(progn
      (setq tens (substr (substr currentrevision (- revlength 1) 2 ) 1 1))
      (if (and (= 1 anumber) (numberp (read tens))) (setq anumber 2))
  (if (< 2 revlength)(progn
      (setq hundreds (substr (substr currentrevision (- revlength 2) 2 ) 1 1))
      (if (and (= 2 anumber) (numberp (read hundreds))) (setq anumber 3))
  (if (< 3 revlength)(progn
      (setq thousands (substr (substr currentrevision (- revlength 3) 3 ) 1 1))
      (if (and (= 3 anumber) (numberp (read thousands))) (setq anumber 4))
;;work out numerical revision.
  (if (> anumber 0)
      (setq revnumber (substr currentrevision (- revlength (- anumber 1)) anumber))
      (setq revnumber (itoa (+ 1 (read revnumber))))
      (if (and (> revlength anumber)(/= revlength anumber))
        (setq revisionprefix (substr currentrevision 1 (- revlength anumber))) ;;first characters of revision
      ;;fix leading zeros
      (setq leadingzeros (- anumber (strlen revnumber)))
      (if (= 3 leadingzeros)(setq leadingzero "000"))
      (if (= 2 leadingzeros)(setq leadingzero "00"))
      (if (= 1 leadingzeros)(setq leadingzero "0"))
      (if (> 1 leadingzeros)(setq leadingzero ""))
      (setq revletter (strcat revisionprefix leadingzero revnumber))
;;Work out letters revisions
  (if (= anumber 0)
      (setq revcode (+ 1 (ascii ones)))
      ;;set exceptions here
      (if (= 73 revcode)(setq revcode 74)) ;;I
      (if (= 79 revcode)(setq revcode 80)) ;;O
      (if (= 105 revcode)(setq revcode 106)) ;;i
      (if (= 111 revcode)(setq revcode 112)) ;;o.. its of to work we go.
      (if (= 91 revcode)(setq revcode 65)) ;;Z -> A. Won't increment 'tens' value
      (if (= 123 revcode)(setq revcode 97)) ;;z -> a Won't increment 'tens' value
      (setq revisionprefix (substr currentrevision 1 (- revlength 1))) ;;first characters of revision
      (setq revletter (strcat revisionprefix (chr revcode)))
  (setq entlst (subst (cons 1 revletter) (assoc 1 entlst) entlst))
  (entmod entlst)
  (entupd ent)
  (setvar "CMDECHO" 0)
  (command "regen") ;;in case of nested blocks
  (setvar "CMDECHO" 1)
  (princ ent)
I use it to increase revision codes mostly (hence the name 'uprev')
Its not perfect and since I wrote it for me, not pretty. The last character will increase by 1, so 15.QF5 -> 15.QF6. It should work with blocks, mtext, text (just checked, dimensions too). Also it will increment letters to the next highest (A ->B or d ->e retaining the letters case (upper or lower)). There are a couple of lines to ignore I and O (we don't use them as revision codes generally), I've left that in there for your information. It it limited in that numbers will increase by 1 even to the next magnitude (so 7, 8, 9, then 10), letters won't - it won't go X, Y, Z, AA, AB mostly by design that with letters it isn't always that clear what the sequence should after Z
Feel free to use it, modify or whatever
Hope I am answering the right thing here!
Another one for fun :)
(defun _foo (s n / a b)
  (cond	((/= s (setq a (vl-string-right-trim "1234567890." s)))
	 (setq b (vl-princ-to-string (+ n (read (substr s (1+ (strlen a)))))))
	 (strcat (substr s 1 (strlen a)) b)
(setq i "15.QF5")
(repeat 10 (print (setq i (_foo i 1))))
;;;"15.QF6"
;;;"15.QF7"
;;;"15.QF8"
;;;"15.QF9"
;;;"15.QF10"
;;;"15.QF11"
;;;"15.QF12"
;;;"15.QF13"
;;;"15.QF14"
;;;"15.QF15"
15.QF9 → 15.QF10
15.QF9 → 15.QG0
15.QF9 → 15.QG1
Which is correct?
Edited by Lee Mac
Hello and thank you all for the answers!...The change I had indicated from 15.QF5 to 15.QF6 was an example, in fact I was looking for a universal solution to increase a figure quickly and...WOW! The UPREV lisp it's great! Thank you Steven P!
In the next days, after having tried it every day, I will write to you again, in the meantime, thank you again
Not a problem.. though if Lee Mac has a solution they are generally more elegant and bug free than anything I would write
Lee asked a question, an uncomplete-structured demand may lead to uncomplete or undesired solution. so...
Quote
23 hours ago, Lee Mac said:
15.QF9 → 15.QF10
15.QF9 → 15.QG0
15.QF9 → 15.QG1
Which is correct?
All three are correct ... it depends on the need of everyone ... mine is a silly answer, but I'm preparing an example to represent some typical situations like ... once shown maybe I'll be more clearly!
On 10/31/2018 at 10:21 PM, Lee Mac said:
15.QF9 → 15.QF10
15.QF9 → 15.QG0
15.QF9 → 15.QG1
Which is correct?
If the second example is desired, you could use my numinc:incrementalpha function which appears on lines 4,375-4,427 of my Incremental Numbering Suite application.
For example:
_$ (numinc:incrementalpha "15.QF9" 1)
"15.QG0"
_$ (numinc:incrementalpha "15.QF9" 10)
"15.QG9"
_$ (numinc:incrementalpha "15.QF9" 100)
"15.QP9"
_$ (numinc:incrementalpha "15.QF9" 1000)
"15.UB9"
That's very flattering of you to say Steven - though, we all stand on the shoulders of giants and were all a beginner once 😉
Hi, I allow myself to make two considerations on the very useful lisp, but as a non-programmer I hope not to say too risky things...
The correction of an alphanumeric code is unpredictable, I can not know which example to give what is happening in this discussion...but it is possible to read, at the time of the change, which digit should be corrected...
I think this lisp should have the choice of:
1) increase / decrease (by default increase)
2) the specification of the position of the digit to be changed (by default the last one)
Obviously I have no idea how difficult or feasible it can be to put the second point into practice.
For the first point instead would it be possible? choose whether to increase or decrease?
Many greetings
To decrease the number / letter
Copy the whole lot and change this to create a new LISP, DownRev - simplest way to do that so there is no need to choose what to do in a single LISP.
defun c:uprev
to
defun c:downrev
to
(setq revnumber (itoa (- 1 (read revnumber)))))
to
(setq revcode (- 1 (ascii ones)))
However it will probably not work right for number 1 or 0, and for letter A or a - but you can look at changing that about
try changing
to
(if (= 65 revcode)(setq revcode 91))
for example.
For altering a character that isn't the last one, its possible but will need a bit more thinking about for me
You might want to use the function 1-
(1- 6.)
;;5.0
(- 1 6.)
;;-5.0
Thanks RonJon - like I said, mine isn't pretty and there are better ways, I'll change it round when I get a chance
No worries .. just an observation :)
  • 3 weeks later...
Hello...I could not properly modify the lisp to perform the correct decrement of the digits, patience, I will try again...
A further change that I ask you to explain is the following: is it possible to make the command reload to be used longer until the command is closed?
I was watching this discussion:
the first lines of the lisp (which works as I would like) have the following instruction:
(while (or (setq nent (nentsel "\nPick attribute. Right click to exit"))
But i don't know how insert in the uprev lisp.
Regards
