help me, please!!! not working
hailualua
(defun 😄Copytest (/ curr_dir  foldrflname  edFname  edPath)
  (vl-load-com)
  (setq edPath "D:\\")
  (setq edFname "05a_fr_54.dwg")
  (setq foldrflname (strcat edPath  edFname ))
   (setq curr_dir (strcat (getvar "dwgprefix") ))
    (vl-file-copy  (apply 'strcat foldrflname)  curr_dir)
Edited by hailualua
(vl-file-copy source-file destination-file)
This is the correct syntax
curr_dir is NOT  a destination FILE
Your error arises because you are attempting to use the apply function with a string argument as opposed to a list argument:
Here, your variable foldrflname is a string, as returned by the earlier strcat expression:
(setq foldrflname (strcat edPath edFname))
But that aside, you will also need to specify a valid filename for the destination of your vl-file-copy expression, e.g.:
(defun c:copytest ( / edpath edfname )
    (setq edpath  "D:\\"
          edfname "05a_fr_54.dwg"
    (vl-file-copy (strcat edpath edfname) (strcat (getvar 'dwgprefix) edfname))
Edited by Lee Mac
