Cadburg
Round down area field in Lee-Mac code
Cadburg
Please, help me in some question. I've been using the lisp the Lee-Mac code for area fields( Areas2FieldV1-3.lsp ) - http://lee-mac.com/areastofield.html, but I need to round down an area values. What should I change in code to get that values?
For example, the value 23,8 m2 should be displayed like 23,5, or 80,23 should be 80,0. Thank you in advance
Share this post
Link to post
Lee Mac
Welcome to CADTutor :thumbsup:
Unfortunately, it's not a simple change - replace lines 59-86 (inclusive):
            (if (= 1 (sslength sel))
                (setq str
                    (strcat
                        "%<\\AcObjProp Object(%<\\_ObjId "
                        (LM:ObjectID (vlax-ename->vla-object (ssname sel 0)))
                        ">%).Area \\f \"" fmt "\">%"
                    (repeat (setq idx (sslength sel))
                        (setq lst
                            (vl-list*
                                (LM:ObjectID (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))))
                                ">%).Area>%" " + "
                                lst
                    (setq str
                        (strcat
                            "%<\\AcExpr "
                            (apply 'strcat (reverse (cdr (reverse lst))))
                            " \\f \"" fmt "\">%"
With the following code:
                (setq lst
                    (vl-list*
                        ">%).Area>%" " + "
                        lst
            (setq str
                (strcat
                    "%<\\AcExpr (Trunc(("
                    ")/0.5)*0.5) \\f \"" fmt "\">%"
Edited by Lee Mac
  • Thanks 1
Share this post
Link to post
Cadburg
Thank you very much, Lee Mac! Your code helped me a lot
Share this post
Link to post
Dungnguyen
                (setq str
                    (strcat
                        (setq lst
                            (vl-list*
                                ">%).Area>%" " + "
                                lst
                    (setq str
                        (strcat
                            "%<\\AcExpr "
                (setq lst
                    (vl-list*
                        ">%).Area>%" " + "
                        lst
            (setq str
                (strcat
Help:
Please, help me in some question. I've been using the lisp the Lee-Mac code for area fields( QuickFieldV1-3 ), but I need to round 5 . What should I change in code to get that values?
For example, the value 11203 should be displayed like 11205, or 11208 should be 11210. Thank you in advance
Share this post
Link to post
Dungnguyen
On 12/2/2018 at 5:53 PM, Lee Mac said:
You're welcome! @Cadburg 🍺
(defun c:ts1 ( )(LM:QuickField "Length" "%lu2%pr0%ps[,]%ct8[1]" 1))
(setq str (LM:quickfield:constructfieldstring prop format))
(setq Z (/ str 5) )
(setq Z1 (fix Z) )
(setq Z2 (- Z Z1) )
(setq Z3 (IF (>= Z2 0.5) (+ Z1 1) Z1))
(setq Z4 (* Z3 5) )
I want Z4
Help!
Share this post
Link to post
