masterfal
block updating
masterfal
Hi All,
I have a lisp routine I use for updating blocks which prompts me for the block name or if use ? it lets you click on the block you want to update. How can I remove the prompt for block name, so first up it asks you to choose/click block instead of typing name? Would be good if they could be swapped so using ? prompts you for the block name otherwise if its easier would be happy if the prompt for block name was completely removed
;Block redefinition - for batch scripts
;replaces <BLKNAME> with a new version of the block saved in <BLKNAME>.DWG
;(DWG file must be on search path)
(defun C:BUP ( / blkname cmde ss)
 (setq cmde (getvar "cmdecho"))
 (setvar "cmdecho" 0)
 (setq blkname (getstring "\nBlock name ('?' to pick): ")) ; rem
;added 7/2013
  (if (and blkname (= blkname "?"))(progn ; rem
  (prompt "\nPick a block:")
  (setq ss (ssget ":S" '((0 . "INSERT"))))
  (if ss (setq blkname (cdr(assoc 2 (entget(ssname ss 0))))))
  (princ blkname)
 )) ; rem
 (if (tblsearch "block" blkname)
;   (command "._-insert" (strcat blkname "=") "_y" nil "_regen") ; breaks scripts...
   (command "._-insert" (strcat blkname "=") "_y" "@")
   (while (= (logand (getvar "CMDACTIVE") 1) 1)(command "")) ; for scripts
   (entdel (entlast))
   (command "_regen")
   (princ (strcat "\nBlock " (strcase blkname) " redefined."))
  (princ "Block not found.")
 (setvar "cmdecho" cmde)
 (prin1)
Share this post
Link to post
Grrr
Maybe something like:
(defun C:BUP ( / blkname cmde )
  (if (setq blkname (PickBlock (setvar 'errno 0)))
      (entdel (entlast))
      (command "_regen")
; (PickBlock (setvar 'errno 0))
(defun PickBlock ( e )
  (cond
    ( (not e) e )
      (or
        (and (= 7 (getvar 'errno)) (princ "\nMissed") (setvar 'errno 0))
        (not (setq e (car (entsel "\nPick block: "))))
        (and (/= "INSERT" (cdr (assoc 0 (setq e (entget e))))) (princ "\nIvalid object"))
      (PickBlock (/= 52 (getvar 'errno)))
    ( (cdr (assoc 2 e)) )
Share this post
Link to post
masterfal
Cheers Grrr!!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
