smuthuc
BLOCK INSERT USING VBA
smuthuc
NOT WORKING MY VBA CODE
Public Sub index_test()
Dim strPath As String
Dim strBlockName As String
strBlockName = "INDEX"
strPath = "E:\Soft\Template\INDEX.dwg"
'On Error Resume Next
DbxCopyBlock strBlockName, strPath
strBlockName = "BSC1"
Dim Pt1 As Variant
Pt1 = ThisDrawing.Utility.GetPoint(, "Pick the Index Table Corner:")
Dim BlkNme As AcadBlock
Dim BlkRef As AcadBlockReference
Set BlkRef = ThisDrawing.ModelSpace.InsertBlock(Pt1, strBlockName, 1, 1, 1, 0)
End Sub
Sub DbxCopyBlock(strBlockName As String, strPath As String)
Dim strFullDef As String
Dim objBlock As AcadBlock
Dim colBlocks As AcadBlocks
Dim objArray(0) As Object
Dim ACDbx As Object
   Set ACDbx = GetAcDbxDoc()
   ACDbx.Open strPath
   Set colBlocks = ACDbx.Blocks
   Set objBlock = colBlocks.Item(strBlockName) 'Find appropriate block in container file's Blocks Collection
   Set objArray(0) = objBlock 'Create object array as required by the CopyObjects Method
   ACDbx.CopyObjects objArray, ThisDrawing.Blocks 'Copy to current drawing's Blocks Collection
   Set ACDbx = Nothing
End Sub
Function GetAcDbxDoc() As Object
Dim strAcadVersion As String
With ThisDrawing.Application
   strAcadVersion = Mid(.Version, 1, 2)
   If CInt(strAcadVersion) < 16 Then
       Set GetAcDbxDoc = .GetInterfaceObject("ObjectDBX.AxDbDocument")
   Else
       Set GetAcDbxDoc = .GetInterfaceObject("ObjectDBX.AxDbDocument." & strAcadVersion)
   End If
End With
End Function
PLEASE RECTIFY ANYBODY
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
