Awallace24335 Posted December 4, 2018 Posted December 4, 2018 Hello, I'm trying to add chainage points along a poly line at intersection points. i have a Lisp that will do it every 10 Meters. However i would like to be able to do it from a start point and then at each selected intersection point. Basically i off-set points on a road but i would like to know at what chainage these are at. drawing attached with manually entered Chainage labels Road Design CT.dwg Quote
BIGAL Posted December 5, 2018 Posted December 5, 2018 (edited) Very simple if you look at the chainage code you will more than likely find a vl-getpointatdist so you need to work backwards and get the vertice points and then work out the running chainage. If you search for length at point on pline you should find an answer I will look also. Pretty sure it exists. A sledge hammer approach is to trim the pline and get length then undo to restore. Edited December 5, 2018 by BIGAL Quote
CyberAngel Posted December 5, 2018 Posted December 5, 2018 If you have Civil 3D, why not create a new alignment along each segment? Or one long alignment? That lets you set the beginning distance for each segment, and it gives you the offset automatically. Quote
Awallace24335 Posted December 11, 2018 Author Posted December 11, 2018 On 12/5/2018 at 2:27 PM, CyberAngel said: If you have Civil 3D, why not create a new alignment along each segment? Or one long alignment? That lets you set the beginning distance for each segment, and it gives you the offset automatically. This is way beyond my knowledge. I’m new to c3d and trying to advance in it thanks for your reply Quote
BIGAL Posted December 12, 2018 Posted December 12, 2018 Try this in CIV3D, toolspace, toolbox,Reports manager, Alignment. Pick a report Quote
Awallace24335 Posted December 12, 2018 Author Posted December 12, 2018 8 hours ago, BIGAL said: Try this in CIV3D, toolspace, toolbox,Reports manager, Alignment. Pick a report Thanks BIGAL tried this and it is exactly what I require. I have one problem though. In Drawing scale 1:1 and in meters the points and text are either massive or not visible they seem about right at 4:1. I’m tried to edit text heights with no joy Thanks Quote
SLW210 Posted December 12, 2018 Posted December 12, 2018 I have moved your thread to the Civil 3D & LDD Forum. Quote
