TunzaGibbo
lisp commands
TunzaGibbo
I want my lisp file to insert a block in a certain way.
After "_insert" I would like the program to go to a specific folder where I keep my blocks.
This code works fine if I have a block name where the question marks are. Is there some code I can enter where the question marks are to get the dialogue box?
(command "_insert" "??????????" pause 1 "" 0 )
Share this post
Link to post
Lee Mac
Here is one option:
(if (setq blk (getfiled "Select block" "" "dwg" 16))
    (command "_.-insert" blk "_S" 1 "_R" 0 "\\")
Share this post
Link to post
TunzaGibbo
Thank you Lee
(command "_insert" "C:\\Users\\Tony Clean Install\\#Advance\\Blocks\\Cameras\\Camera HD Detail.dwg" pause 1 "" 0 )
if I was to use this line (which works well) How could I incorporate in this line the ability to explode the block
regards
Tony
Share this post
Link to post
asos2000
(if (and
    (vl-cmdf "_insert" "C:\\Users\\Tony Clean Install\\#Advance\\Blocks\\Cameras\\Camera HD Detail.dwg" pause 1 "" 0 )        ; inser block
    (setq CMHDD (ssget "x" '((0 . "INSERT") (2 . "Camera HD Detail"))))
      (vl-cmdf "_.EXPLODE" CMHDD "")
      (vl-cmdf "_.-purge" "blocks" "Camera HD Detail" "n")
Share this post
Link to post
BIGAL
Why not explode entlast !
Share this post
Link to post
asos2000
👍 Yes
Share this post
Link to post
Lee Mac
Alternatively, you could use something like this:
(setq pth "C:\\Users\\Tony Clean Install\\#Advance\\Blocks\\Cameras\\Camera HD Detail.dwg"
      blk (vl-filename-base pth)
(if (or (tblsearch "block" blk)
        (and
            (or (findfile pth)
                (prompt (strcat "\n" pth " not found."))
            (or (progn
                    (command "_.-insert" pth nil)
                (prompt (strcat "\n" blk " could not be defined."))
    (command "_.-insert" (strcat "*" blk) "\\" 1 0)
Share this post
Link to post
TunzaGibbo
Thankyou everyone for your contributions.
This is what I am finally using and it works perfect.
(command "_insert" "Camera HD Detail.dwg" pause 1 "" 0)(setq blex (entlast))(command "_explode" blex)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
