jan_ek
Autolisp - camera position
jan_ek
Hello
I would like to save view position to txt file.
What variables do I need to save?
Share this post
Link to post
marko_ribar
PERSPECTIVE
VIEWDIR
VIEWCTR
Basically VIEWCTR = TARGET, when UCS=WCS (mapcar '+ (getvar 'VIEWCTR) (getvar 'VIEWDIR)) = CAMERA, PERSPECTIVE (1= in perspective, 0= in parallel vector projection)
Share this post
Link to post
jan_ek
Hello
Thanks for quick answer but how restore this variable.
Share this post
Link to post
ronjonp
You want to save the camera location to a text file? A quick properties dump has all the info I think you need:
Quote
; IAcCameraWrapper: IAcCameraWrapper Interface
; Property values:
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00007ff633f06558>
;   BackPlane = 0.0
;   Clipping = "Off"
;   Document (RO) = #<VLA-OBJECT IAcadDocument 0000025166e7f698>
;   EntityTransparency = "ByLayer"
;   FieldOfView = 0.691111
;   FrameHeight = 4.35699
;   FrameWidth = 6.53549
;   FrontPlane = 0.0
;   Handle (RO) = "9E"
;   HasExtensionDictionary (RO) = 0
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 000002516fa7e228>
;   IsPlotable = 0
;   Layer = "*temporary_system_cameras_layer"
;   LensLength = 50.0
;   Linetype = "ByLayer"
;   LinetypeScale = 1.0
;   Lineweight = -1
;   Location = (2.76479 4.11262 0.0)
;   Material = "ByLayer"
;   Name = "Camera1"
;   ObjectID (RO) = 43
;   ObjectName (RO) = "AcDbCamera"
;   OwnerID (RO) = 44
;   PlotStyleName = "ByLayer"
;   RollAngle = 0.0
;   Target = (11.4619 7.54752 0.0)
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 000002516fa7e700>
;   Visible = -1
; Methods supported:
;   ArrayPolar (3)
;   ArrayRectangular (6)
;   Copy ()
;   Delete ()
;   GetBoundingBox (2)
;   GetExtensionDictionary ()
;   GetXData (3)
;   Highlight (1)
;   IntersectWith (2)
;   Mirror (2)
;   Mirror3D (3)
;   Move (2)
;   Rotate (2)
;   Rotate3D (3)
;   ScaleEntity (2)
;   SetXData (2)
;   TransformBy (1)
;   Update ()
Share this post
Link to post
marko_ribar
6 hours ago, jan_ek said:
Hello
I think you can use DVIEW command with PO - points option and enter coordinates... For perspective use (setvar 'perspective 1) or (setvar 'perspective 0)...
Share this post
Link to post
jan_ek
Hello, I can not use this suggestions.
Perhaps I have asked the question wrong or i don't understand answers
I would like to:
1. Save view to file.
2. Load save file
3. Automatically rotate and zoom view (use variable to file).
Share this post
Link to post
David Bethel
Have you looked into the view table.
Command : _.VIEW -Save TEST
Command : (tblsearch "VIEW" TEST)
The table can be saved to a text file and fairly easily restored.
-David
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
