norman Posted December 7, 2018 Share Posted December 7, 2018 Hi if you have a blueprint machine in office you are required to print your drawing in that machine it is not required to print first tracing paper then blueprint on this type of machine it is automatic..my question is if it required to change your plotsyle if your printing your drawing in pdf then you blueprint it in this machine? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 10, 2018 Share Posted December 10, 2018 We have multiple plot settings for the same size sheet, its about changing line thickness the smaller the sheet the finer the line work, so if we were to plot a A1 sheet onto a A4 sheet we use a finer linetype pen settings, A1 to A1 thicker lines, hopefully this answers your question. Quote Link to comment Share on other sites More sharing options...
