lisp to find the centroid of a selected area
Elektrik
Is there any lisp to find/mark the centroid of any area you select, just when you run with the area command, you can select any area you want without polygons or regions. Is there any lisp find the centroid of an area when you specify points that define that area?
Thanks in advance.
Study this example and it should be clear to you what to modify to get sub function work with point list... Note that it would be preferable to draw polygon in advance as segments must not cross each other... So actually you don't need to modify anything from Lee's examples - you have to provide LWPOLYLINE polygon ENAME as an argument...
http://www.lee-mac.com/polygoncentroid.html
HTH., M.R.
Hi,
Give this a shot and let me know.
(defun c:cnt ( / nxt pnt lst obj reg cen)
  ;; 	Tharwat - Date: 08.12.2018		;;
  ;; Print Centriod point from picked points.	;;
  (cond ((= 4 (logand 4 (cdr (assoc 70 (entget (tblobjname "LAYER" (getvar 'CLAYER))))))) (alert "Current layer is locked<!>"))
        ((and (setq nxt " ")
              (while (setq pnt (getpoint (strcat "\nSpecify" nxt "point : ")))
                (setq lst (cons pnt lst)
                      nxt " Next ")
              lst
              (setq obj (entmakex (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 90 (length lst)) '(70 . 1))
                                                (mapcar (function (lambda (p) (cons 10 p))) lst))))
         (cond ((vl-catch-all-error-p (setq reg (vl-catch-all-apply 'vlax-invoke (list (vla-get-block (vla-get-activelayout (vla-get-ActiveDocument
        (vlax-get-acad-object)
        'Addregion
        (list (vlax-ename->vla-object obj))
                (alert "Error. Can't create the region <!>"))
               (t    (setq reg (car reg)
                           cen (vlax-get reg 'Centroid))
                (alert (strcat "Centriod = " (vl-princ-to-string cen)))
                (print cen)
                (vla-delete reg))
  (and obj (entdel obj))
  ) (vl-load-com)
(princ "\nType CNT to start.")
2 hours ago, Tharwat said:
Hi,
                      nxt " Next ")
              lst
        'Addregion
                (print cen)
                (vla-delete reg))
  ) (vl-load-com)
Thanks, this is just what I wanted, except it does not mark the centeroid. It would be better if it did. Thanks again.
Just replace this:
with this:
(entmake (list '(0 . "POINT")  (cons 10 (trans cen 0 1))))
And get sure is that the PDMODE system variable is other than zero to be able to see the mark point.
Edited by Tharwat
1 hour ago, Tharwat said:
Just replace this:
with this:
(entmake (list '(0 . "POINT")  (cons 10 cen)))
Thanks, but it marks somewhere outside the selected area I am not sure why.
You must have your UCS other than World system and that's why the mark point located somewhere else.
Anyway, I have updated my previous post and please replace them again then try again.
NOTE: its not necessarily to quote every reply to write a reply but its up to you anyway.
  • 3 years later...
2 hours ago, Maharshi555 said:
Simply use this:
(setq cen_pt (ade_expreval ent_one ".center" "point"))
ent_one is the entity
of course, ade_expreval is an AutoCAD 3d MAP command and won't work if they don't have that installed.
I am assuming center point = geometric center
(setq poly (vlax-ename->vla-object (car (entsel "\nSelect polyline"))))
(setq CPT (osnap (vlax-curve-getStartPoint poly) "gcen"))
