Hi All.
I'm new to custom line styles but was doing OK until I tried to draw my custom line from right to left.
This is the code I wrote:
*FOUL_PIPE,Foul Pipe --FP[B1]----FP[B1]----FP[B1]----FP[B1]----FP[B1]----FP[B1]--
A,1.5,-1.5,["FP(B1)",STANDARD,S=.2,U=0.0,X=-1.25,Y=-0.1],-.01
and below is the result I got.
As you can see, I've set the rotation U=0 as advised on the web.
I believe it has something to do with the insertion point of the text, but I'm at a loss how to resolve it.
Any help much appreciated
Thanks, Bob
Unfortunately, the culprit is the U factor which always assures that the text is upright, and in the linetype definition, the text is left justified.
Until AutoCAD set up a middle justification of the text, the best thing to do is make the line a polyline, and reverse its direction.
Thanks Eldon. If I do this it'll reverse all the text that is correct i.e. drawn drawn left t right. I think I may have found the solution by creating the line style within Express Tools. I'll continue to tinker and update the post.
