Direction of a construction line (xline)
Thank you
I only knew the last 2 lines.
Well done
(setq Segments (getreal "\nNumber of Segments::"))
(setq ent (car (entsel "\nSelect line :")))
  (setq lst (entget ent))
  (setq startpoint (cdr (assoc 10 lst)))
  (setq end (cdr (assoc 11 lst)))
  (setq len (distance startpoint end)) ;; length
  (setq ang (angle startpoint end))
  (command "_xline" "A" (+ ang 90) startpoint "")
  (setq Conline (entlast))
(command "_copy" Conline "" "O" "M" startpoint "A" segments (polar startpoint ang (/ len segments)))
with this one I have a line and want to insert an XLINE at 90 deg to that line staring at "startpoint" and then copy that the XLINE along "Conline" a distance of "len" divide by "segments"
Example: Line 200 long result would be Segments=10 I would have 11 Xlines spaced equally along the 200 line
regards
Tony
  • Replies 24
  • TunzaGibbo
    13
  • Tharwat
    10
  • BIGAL
    1
  • Grrr
    1
Posted Images
Everything works down to the end of the 9th line
Thank you
Well done
regards
Tony
Although I'd use the vlax-curve-* functions...
You could try yourself with the polar function to calculate each point where every xline must intersect (by knowing the segment's length).
Also your first line doesn't seem correct, perhaps you wanted to use getint ?
Just another hint you can use (entlast) to save the last entity, saves doing a pick object if that’s helpful.
