Steps to enable Drag Drop Feature
kalindiberad
It would help to have more information. What happens in drag&drop depends on what you drag and where you drop it. For instance, if you drop a drawing onto the AutoCAD icon, it opens as its own drawing, whereas if you drop it into your drawing space it becomes a block inside the current drawing. Also, the operating system (and the version of it) you have can affect drag&drop. Have you recently upgraded your OS? What are you attempting to drag? Where are you dropping it? What is the desired outcome?
