error: string too long on input
wimal
with WRITE-LINE function I need to attach a long string.But error message is coming when feed a long string.
Is there a method to feed long strings?
How about write-char?
p/s FYI I've seen software similar @Tharwat's split method to convert string to (eg: com port devices) '*.raw' format which string data was 'chopped' to an 8bit-block (128 ascii char for each line) with bcc checksum
  • Thanks 1
18 hours ago, Tharwat said:
Divide the long string into parts to be able to write them to your target file.
Ye s it was very easy . I added  (write-line "5555555" fn) (write-line "66666666" fn)
This must be better:
(foreach string '("a" "b" "c")
  (write-line string fn)
  • Thanks 1
