amir0914
Count of object in specific layer
amir0914
hi guys, i need a lisp to get Count of Object in a specific layer by get layer name, can someone help me?
Share this post
Link to post
amir0914
hi thanks, i have seen that topic already, but i want to know count of object only in one layer, i wrote this code but it doesn't work : (sorry i'm beginner in autolisp)
(defun c:LC ()
  (setq acadObj (vlax-get-acad-object))
  (setq doc (vla-get-ActiveDocument acadObj))
  (setq cnt (vla-get-Count (vla-item (vla-get-Layers doc) "Wall")))
"Wall" is layer name
Edited by amir0914
Share this post
Link to post
marko_ribar
(defun c:LC nil
  (if (ssget "_X" '((8 . "Wall")))
      (prompt "\nTotal : ") (princ (sslength (ssget "_X" '((8 . "Wall"))))) (prompt " entities in Layer : \"Wall\"")
    (prompt "\nNo entities in Layer : \"Wall\"")
Share this post
Link to post
amir0914
Thank you marko, i used your code and my problem is resolved,
Which part of my code is wrong??
Edited by amir0914
Share this post
Link to post
BIGAL
A little add on not hard codedfor layer name.
(defun c:LC ( / layname )
  (setq layname (vla-get-layer (vlax-ename->vla-object (car (entsel)))))
  (if (setq ss (ssget "_X" (list (cons 8 layname))))
    (Alert  (strcat "\nTotal : " (rtos (sslength ss) 2 0) " entities \n\nIn Layer : " layname))
    (Alert (strcat "\nNo entities in Layer : " layname))
(c:lc)
 (vla-get-Layers doc) this gets the list of layer names from the layer table, not objects within that layer.
Edited by BIGAL
Share this post
Link to post
Lee Mac
A VLA Layer object does not have a count property - you can check the available properties & methods for an object using the vlax-dump-object function.
Share this post
Link to post
ronjonp
I think you're missing a few closing parenthesis 😉
Share this post
Link to post
BIGAL
Thanks ronjonp must have cut and pasted wrong.
Share this post
Link to post
amir0914
Thank you  all for your honest help and advice,
lee Mac, I check and study vlax-dump-object , it was useful and great.
Share this post
Link to post
Lee Mac
You're most welcome @amir0914 - You may find my Dump Object utility useful in this regard - it's a simple program and merely a wrapper for the vlax-dump-object function to allow you to select a primary or nested object.
Share this post
Link to post
Grrr
Lee, just an idea for fun - you could include accepting a handle argument [STR]. :)
Share this post
Link to post
Lee Mac
An excellent idea Grrr!
I have now updated the utility to achieve exactly that - I've also rewritten it to handle the various data types more elegantly - thank you for this suggestion. :thumbsup:
Edited by Lee Mac
Share this post
Link to post
amir0914
Thank you Lee mac, Sorry for the delay in replying, I see your website and post about Dump-Object, I'm sure it will help me a lot , thanks again..
Share this post
Link to post
