Create layers then assign color and linetype
hemsley
Working through the Autodesk .NET Developers Guide Samples 2019. (very new to all this).
They have a sample code: Assign Colour to a Layer (.NET) where three layers are created and each layer is assigned a different colour.
How would I expand that code so that in a addition to the assignment of colours I could load and then assign three different line-types from acad.lin.
Nested transaction? Or create an array for line-types?
Any help would be greatly appreciated.
  • 2 weeks later...
Done in lisp or VBA you need to check if a linetype exists if not load it, then you can assign a layer a particular line type, should be a similar method to colour.
