Rotechica
LISP to export line and block counts
Rotechica
Hi there,
I am quite new to lisps (and attempting to write them), I 'm trying to find a lisp that can extract block and line information into excel.
As an example the LISP outcomes would be:
-Selecting a number of objects (lines and blocks)
-Counting the number of lines per layer, and the total length of those lines per layer
-Counting number of blocks and dynamic blocks per layer
-Listing the values of those counts and exporting as a csv file
If anyone knows of a LISP like this that already exists or could help point me in the right direction to write my own that would be a massive help!
Thanks again to anyone who has the time :)
Share this post
Link to post
enthralled
Try dataextraction, I think it does what you need.
Share this post
Link to post
Rotechica
I have seen Lee Mac's DBCount V1-1 which is the output I am looking for... Basically wondering if there is a LISP that includes the selection and counting of other objects (lines/polylines etc), not just blocks/dynamic blocks, and breaks them down per layer
Share this post
Link to post
Lee Mac
You could try my Layer Count program posted here.
Share this post
Link to post
Rotechica
Thanks, just gave it a try however it came up with an error saying 'too few arguments'
Share this post
Link to post
Lee Mac
I cannot reproduce this error - are you sure you have copied & saved the code correctly?
Share this post
Link to post
Rotechica
I got it working after I removed the BB codes :)
This is really close to what I am after but not quite it. It might help if I add that the outcome for this is to create a high level Bill of Materials eg calling layers DNxxx pipe , and the blocks in question being manholes and valves ect. then it would be a brief summary saying within the drawing there are 123 number of lines equalling a total length of 456m for DN789  pipe (this being repeated per layer), and there are 123 number of valves, 456 number of manholes ect.
Thanks so much for the help, I really appreciate all your work
Share this post
Link to post
BIGAL
Something I was working on a while ago but it fell to the side was a user driven dataextraction basicaly it did counts and produced a table of the results. So for blocks of same name but with different attributes it would do counts at the multi level of attributes.
Manhole concrete >1m 52
Manhole concrete >2m 34
Manhole steel lid 26
Its not finished but I would appreciate a sample dwg for testing and support those who input, the final product is more than likely to be  shareware code.
Share this post
Link to post
Rotechica
Sorry for taking so long to reply,
I have attached a drawing to help. I can chat to you about good outputs/help where I can (If there is a direct messaging feature here instead of using the thread the whole time)
Quantity_LISP_for_testing.dwg
Share this post
Link to post
BIGAL
I have been very busy lately moved house but will try to have a look at it over the next couple of days.
Share this post
Link to post
