YannickMeuleman
Making autopublish drawing specific
YannickMeuleman
Good day CAD-tutors
I work at a company wich manages several buildings (aprox 60 buildings)
I manage all the floorplans for the buildings and make sure these stay up to date.
Besides the DWG files, I need to keep PDF files ready for co workers to open and see the most up to date version of the buildings.
At the moment, each time I make a change, i need to remember to plot a specific layout to a specific place on our fileserver.
This sometimes gets forgotten and I want to automate the proces.
Is it in any way possible to make Lisps drawing specific.
I have tried to setup an autopublish, but there are two problems with it.
   -  I want only one of my layouts to be plotted (I can only select to autopublish all the layouts)
   -  Is there a way to automatically let my plot to be saved to a set location per drawing. Location to be different for each drawing. ( At the moment I can only set one location for all the drawings to be put.)
Thanks in advance
Yannick
Share this post
Link to post
f700es
Hello Yannick, I do a very similar job. We are CONSTANTLY updating our building plans. So I am in the same boat. So far we just have to make sure that we publish PDFs after an update is made.
Share this post
Link to post
maratovich
You need :
Once get all the data for printing and settings from the drawing file.
Save a list of settings and print parameters in a separate settings file.
At any time, open this separate configuration file. Automatically for this settings file to print in pdf.
So you can make a lot of configuration files.
Right ?
This can be solved.
Share this post
Link to post
BIGAL
Like Maratovich you can program where a pdf is saved, in our case its always a directory PDF under the dwg location, but every project has its own project number directory. \2019 projects\2019123\design\pdf.
Are all your pdf's in one spot or like what I described ?
Have a look here for plotA3pdfrange2.lsp by me and the excellent plot routine by Maratovich to see if it meets your needs.
Share this post
Link to post
YannickMeuleman
The PDF of each drawing sits in a different file of the file directory. I will give an example:
Building X/plans DWG/Building X_level 1.DWG   --> Location of the DWG file
Building X/plans PDF/Building X_level 1.PDF      --> Location of the PDF file
and so we have a lot of different buildings with different amount of levels.
So the buildup is the same, but the path where it is saved is different for each building.
I will look into your Lisp to see iff I can work with it, I am still a fair beginner at Lisp. But learning fast to solve my 'fix'.
Again thanks in advance for all your replys
Share this post
Link to post
maratovich
Give us an example of your dwg file.
We need to know how your title block is created.
Share this post
Link to post
YannickMeuleman
So this is one of our more simple buildings, but i can be used to explain what i want to do.
Basically, I want to autopublish the layout called 'basis' every time the drawing gets saved.
Autopublish only gives me the option to publish all the layouts.
Each drawing will have its PDF published to a different file location.
D.A.100_Gelijkvloers.dwg
Share this post
Link to post
maratovich
Save to another folder?
Maybe next to the file (in the same folder)?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
