I have got this lsp from some site, using which I can get the polyline area, text inside it, layer and handle tags into csv file.
I would be great i someone could help me by adding polyline length (perimeter) also in this code after polyline area.
(defun c:EPD (/ ss i area layer all_data pts csv_file openfile) ; Export Polyline Data
;;            pBe Sep 2018            ;;
  (if (and
        (setq all_data nil
              ss       (ssget '((0 . "LWPOLYLINE")))
              (setq e     (ssname ss (setq i (1- i)))
                     ent   (entget e)
                    area  (vlax-curve-getarea e)
                     data  (mapcar '(lambda (d)(cdr (assoc d ent))) '( 8 70 5))
                    pts   (mapcar 'cdr
                                  (vl-remove-if-not
                                    '(lambda (d)
                                       (= 10 (car d))
                                    ent
        (setq all_data
                       (cons
                         (list
                (cond
                                      ((null (setq ssText (ssget "_CP" pts '((0 . "TEXT")))))    "-"
                                       ((= (sslength ssText) 1)
                                            (cdr (assoc 1 (entget (ssname ssText 0))))
                                       ((substr
                       (apply 'strcat
                          (mapcar '(lambda (st)
                                     (strcat " | " st))
                            (vl-sort
                              (mapcar '(lambda (s)
                                         (cdr (assoc 1 (Entget s)))
                                      (vl-remove-if 'listp (mapcar 'cadr (ssnamex ssText)))
                              (function (lambda (a b)
                                          (< a b)
                           4
                               area
                               (car data)
                               (if (zerop ( logand 1 (cadr data))) "No" "Yes")
                                  (caddr data)
                         all_data
               all_data
            (setq csv_file (getfiled "Save CSV File"
                                     (strcat
                                       (getvar 'dwgprefix)
                                       (vl-filename-base (getvar 'dwgname))
                                       ".csv"
                                     "csv"
                                     45
          (setq openfile (open csv_file "w"))
          (write-line
            "Text inside polyline,Polyline Area (m2),Layer,Closed,Handle"
            openfile
          (foreach itm (vl-sort all_data
                                '(lambda (a b) (< (Cadr a) (cadr b)))
            (write-line
              (Strcat (Car itm)
                      (strcat (rtos (Cadr itm) 2 2) " m2")
                      (caddr itm)
                      (cadddr itm)
                      (last itm)
              openfile
          (close openfile)
          (startapp "notepad" csv_file)
Try this:
(defun c:epd (/ all_data area csv_file d data e ent i len openfile pts s ss sstext st)
  ;;            pBe Sep 2018            ;;
  (if (and (setq ss (ssget '((0 . "LWPOLYLINE"))))
		   ent	(entget e)
		   ;; RJP » 2019-01-17 added length to results
		   len	(vlax-curve-getdistatparam e (vlax-curve-getendparam e))
		   data	(mapcar '(lambda (d) (cdr (assoc d ent))) '(8 70 5))
		   pts	(mapcar 'cdr (vl-remove-if-not '(lambda (d) (= 10 (car d))) ent))
	     (setq all_data
		    (cons
		      (list
			(cond
			  ((null (setq sstext (ssget "_CP" pts '((0 . "TEXT"))))) "-")
			  ((= (sslength sstext) 1) (cdr (assoc 1 (entget (ssname sstext 0)))))
			  ((substr
			     (apply
			       'strcat
			       (mapcar '(lambda (st) (strcat " | " st))
				       (vl-sort
					 (mapcar '(lambda (s) (cdr (assoc 1 (entget s))))
						 (vl-remove-if 'listp (mapcar 'cadr (ssnamex sstext)))
					 (function (lambda (a b) (< a b)))
			     4
			area
			len
			(car data)
			(if (zerop (logand 1 (cadr data)))
			  "No"
			  "Yes"
			(caddr data)
		      all_data
	     all_data
	   (setq csv_file
			    (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)) ".csv")
			    "csv"
			    45
    (progn (setq openfile (open csv_file "w"))
	   (write-line
	     "Text inside polyline,Polyline Area (m2),Polyline Length (m),Layer,Closed,Handle"
	     openfile
	   (foreach itm	(vl-sort all_data '(lambda (a b) (< (cadr a) (cadr b))))
	     (write-line
	       (strcat (car itm)
		       (strcat (rtos (cadr itm) 2 2) " m2")
		       (strcat (rtos (caddr itm) 2 2) " m")
		       (cadddr itm)
		       (cadddr (cdr itm))
		       (last itm)
	       openfile
	   (close openfile)
Edited by ronjonp
Thanks Ronjonp
It works fine if I select one pline only. But if 2 or more number of plines are selected then it gives error as below:
Error: argument used to compare incorrect: (3.61149 7.70169) (5.12111 9.14575)
Ooops ... should have tested. Code updated above.
Thanks too much.
It works perfectly as I needed.
On 1/18/2019 at 10:24 PM, bills said:
Thanks too much.
Glad to help :)
  • 1 year later...
How would tweak this code to output Area SF and Perimeter LF instead? Tried edit below, without success. Any help would be greatly appreciated.
		       		      (strcat (rtos
          		(cvunit (cadr itm) "sq meter" "sq feet") 2 2) "")
Regards,
Morey
Edited by Morey
The code above will return the area in whatever units you have it drawn in. Just change the m2 and m callouts to f2 and f.
Ronjonp,
For some reason the suggested edit did not work on my end.  The following did work. Gives both Area SQFT and Perimeter FT.
(defun c:EPD (/ all_data area csv_file d data e ent i len openfile pts s ss sstext st)
		   ent	(entget e)
		   area	( / (vlax-curve-getarea e) (* 144));;/ 144 (or 12 * 12) Imperial
		   len	(vlax-curve-getdistatparam e (vlax-curve-getendparam e));;Length Perimeter
	     (setq all_data
		    (cons
		      (list
			(cond
			  ((null (setq sstext (ssget "_CP" pts '((0 . "TEXT"))))) "NO SPACE TEXT FOUND")
			  ((substr
			     (apply
			       'strcat
				       (vl-sort
			     4
			area
			len
			(car data)
			  "No"
			  "Yes"
			(caddr data)
		      all_data
	     all_data
	   (setq csv_file
			    "csv"
			    45
	   (write-line
	     "Space Name/Class,Area (sqft),Perimeter (ft),Layer,Polyline Closed?,Object Handle ID"
	     openfile
	     (write-line
	       (strcat (car itm)
		       (strcat (rtos (cadr itm) 2 2) "")
		       (strcat (rtos (/ (caddr itm) 12) 2 2) "");;or /* Divide or Multiply here
		       (cadddr itm)
		       (cadddr (cdr itm))
		       (last itm)
	       openfile
	   (close openfile)
Assuming your units are set correctly. all you need to do is change this to the output:
(strcat	(car itm)
;; NOTE (getvar 'lunits)
	(strcat (rtos (cadr itm) (getvar 'lunits) 2) " f2")
	(strcat (rtos (caddr itm) (getvar 'lunits) 2) " f")
	(cadddr itm)
	(cadddr (cdr itm))
	(last itm)
Edited by ronjonp
