bcloud73 0 Posted January 18 I am running CADWorx 2019 Plant Pro 2018. I'm working in paper space. My issue is, inside my view port and with the view port set to legacy hidden I have existing pipe that are dashed in the model but when I plot the drawing they show up as solid lines. I have tried everything I know to fix the issue or work around it without doing anything major. Is there way to use legacy hidden and still have the 3D pipe show up as existing pipe? Share this post Link to post Share on other sites
Cad64 42 Posted January 18 You're running Cadworx and Plant Pro inside what program? Autocad? You posted in the 3ds Max section, so I'm a little confused. I think this question probably needs to be moved to the Autocad 3D modeling section. Let me know what Autodesk program you're using and I will move this thread to the proper location. Share this post Link to post Share on other sites
bcloud73 0 Posted January 18 Yes, I am running AutoCad. Thank you, was not sure were to start. Share this post Link to post Share on other sites
Cad64 42 Posted January 18 Ok, I have moved your question. Share this post Link to post Share on other sites
