chubarka
Convert dwg or dxf to pdf
chubarka
Will one of the Gurus here please give me a step by step procedure to convert a dxf, or a dwg file made in Autocad
to a pdf format.
thanking you,
Chubarka
Share this post
Link to post
CyberAngel
You must first locate or create a plotter. Some are free to download. Install the plotter. Use that plotter to print as you would any other device. It will ask for a folder to put the PDF into.
If that's not enough information, ask a more detailed question.
Share this post
Link to post
BIGAL
Autocad has "DWG to pdf" as a printer it should be just there in the available printers.
There are some good tutorials about using layouts and plotting search here 1st or Google.
Share this post
Link to post
chubarka
BIGAL and CyberAngel   Thank you gentlemen!
Share this post
Link to post
SLW210
If you are using AutoCAD 2007 as shown in your profile, I would suggest downloading the FREE latest version of DWGTrueView and use that to plot, I never liked the early version of the plot to PDF myself and I believe they improved it in 2016 version..
From Autodesk Help File AutoCAD 2007
To create a PDF file from an AutoCAD® drawing
Click File menu > Plot.
Select DWG To PDF.pc3 from the Printer/Plotter drop-down list.
Configure other settings in the Plot dialog box, if necessary.
Click OK.
Enter a name for the PDF file and save it to the desired location.
Share this post
Link to post
Cad64
Yeah, I never liked the "dwg to pdf" either, in previous versions, but now it's my default for pdf's. It works great!
Share this post
Link to post
SLW210
Yes, since version 2011, it is all I have used.
Share this post
Link to post
