bills
Leader export of excel along with text and pline length
bills
Hi All
I am looking for a lisp routine using which i can export the following data to excel.
1. selected leader handle & coordinates
2. nearest text to leader tail and
3. nearest pline/line length to leaders head
Can any one help me in this.
Share this post
Link to post
Emmanuel Delay
It gets saved as a CVS.  I save it to "C:\usertemp\leaders.csv".  You should change this to fit your needs, see the top of the code.
Command ELC (for Export Leaders to Cvs)
All leaders are selected.
(vl-load-com)
(setq very_big_number 1000000000)
(setq csvpath "C:\\UserTemp\\leader.csv")  ;; Adapt this to your needs
;; Write CSV  -  Lee Mac
;; Writes a matrix list of cell values to a CSV file.
;; lst - [lst] list of lists, sublist is row of cell values
;; csv - [str] filename of CSV file to write
;; Returns T if successful, else nil
(defun LM:writecsv ( lst csv / des sep )
    (if (setq des (open csv "w"))
            (setq sep (cond ((vl-registry-read "HKEY_CURRENT_USER\\Control Panel\\International" "sList")) (",")))
            (foreach row lst (write-line (LM:lst->csv row sep) des))
            (close des)
            t
;; List -> CSV  -  Lee Mac
;; Concatenates a row of cell values to be written to a CSV file.
;; lst - [lst] list containing row of CSV cell values
;; sep - [str] CSV separator token
(defun LM:lst->csv ( lst sep )
    (if (cdr lst)
        (strcat (LM:csv-addquotes (car lst) sep) sep (LM:lst->csv (cdr lst) sep))
(defun LM:csv-addquotes ( str sep / pos )
    (cond
        (   (wcmatch str (strcat "*[`" sep "\"]*"))
            (setq pos 0)
            (while (setq pos (vl-string-position 34 str pos))
                (setq str (vl-string-subst "\"\"" "\"" str pos)
                      pos (+ pos 2)
            (strcat "\"" str "\"")
        (   str   )
;; Converts a 3d coordinates flat list into a 3d point list
;; recursive function
(defun 3d-coord->pt-lst (lst)
  (if lst
    (cons (list (car lst) (cadr lst) (caddr lst))
      (3d-coord->pt-lst (cdddr lst))
(defun pline_length ( ent / a obj sum)
  (vla-get-length (vlax-ename->vla-object ent))
(defun c:elc ( / leader leaders mtexts plines mtext ip i j ind ind2 pts eol pt2 data)
  ;; get MTexts
  (setq mtexts  (ssget "_x" (list '(0 . "MTEXT"))))
  ;; get leaders
  (setq leaders (ssget "_x" (list '(0 . "LEADER"))))
  ;; Polylines
  (setq plines  (ssget "_x" (list '(0 . "LWPOLYLINE,POLYLINE,LINE"))))
  (setq i 0)
  (setq data (list (list "text" "length" "x head" "y head" "x point 2" "y point 2" "x tail" "y tail")))
  (repeat (sslength leaders)
    (setq leader (vlax-ename->vla-object (ssname leaders i)))
    (setq pts (3d-coord->pt-lst (vlax-get leader 'coordinates)))
    (setq eol (last pts))  ;; end of the leader
    ;; now search for the nearest Mtext
    (setq
      j 0
      ind -1  ;; index of the matching Mtext
      inf very_big_number  ;; a big number, we search for a better match
    (repeat (sslength mtexts)
      (setq mtext (ssname mtexts j))
      (setq ip (cdr (assoc 10 (entget mtext))))
      (princ "\n")
      (if (< (distance eol ip) inf)
          (setq inf (distance eol ip))
          (setq ind j)
      (setq j (+ j 1))
    ;; now we do the same to find the nearest polyline
    (setq
      j 0
      ind2 -1  ;; index of the matching polyline
    (repeat (sslength plines)
      ;; pt2 is the closest point from the hed to the polyline
      (setq pt2 (vlax-curve-getClosestPointTo (ssname plines j) (nth 0 pts) ))
      (if (< (distance (nth 0 pts) pt2) inf)
          (setq inf (distance (nth 0 pts) pt2))
          (setq ind2 j)
      (setq j (+ j 1))
    ;; we have all the data for this row (for 1 leader)
    ;; the (rtos) is to convert numbers to string.  The csv expects string values
    (setq data (append data (list (list
      (cdr (assoc 1 (entget (ssname mtexts ind))))  ;; text
      (rtos (pline_length (ssname plines ind2)) 2 4)           ;; polyline length
      (rtos (nth 0 (nth 0 pts)) 2 4)                           ;; x coordinate head
      (rtos (nth 1 (nth 0 pts)) 2 4)                           ;; y coordinate head
      (rtos (nth 0 (nth 1 pts)) 2 4)                           ;; x coordinate 2nd point
      (rtos (nth 1 (nth 1 pts)) 2 4)                          ;; y coordinate 2nd point
      (rtos (nth 0 (last pts)) 2 4)                            ;; x coordinate tail
      (rtos (nth 1 (last pts)) 2 4)                            ;; y coordinate tail
    (setq i (+ i 1))
  (if
    (LM:writecsv data csvpath)
    (princ "\nSuccessful")
    (princ "\nFailed")
leaders.dwg
Share this post
Link to post
bills
Thanks Emmanuel Delay
Looking at your dwg file, it seems you had understood my requirement perfectly.
But I am unable to use this lsp. It gets loaded but on execution it gives error "Failed" or "Error:Incorrect type - nil"
Please help.
Share this post
Link to post
bills
Its work fine. Actually initially i missed to change the path.
Thanks a lot once again.
Share this post
Link to post
