itacad Posted March 4, 2019 Posted March 4, 2019 Hello, I drew an excel table that is linked to an excel file. I would like to know whether it is possible (perhaps with data fields) to write the value of a table cell, determined by its row and column address, in an attribute of a block. I enclose an example and thank you in advance for any help PROVA TABELLA 1.zip Quote
BIGAL Posted March 5, 2019 Posted March 5, 2019 (edited) Yes pretty easy, once you have a value then update block attribute. put a value (vla-settext objtable row column "A") get a value (vla-gettext objtable row column) Edited March 5, 2019 by BIGAL Quote
itacad Posted March 6, 2019 Author Posted March 6, 2019 Sorry but I don't understand your suggest...could you explain it to me in another way? In the meantime I thought I had found a solution but it did not happen even though I think it's a format problem. I glued screenshots of the steps I did ... who knows if it's the right path PROVA TABELLA 1.dwg Quote
itacad Posted March 7, 2019 Author Posted March 7, 2019 Sorry for my insistence...I am able to link the value of a table cell to an attribute, but does it only work with cells containing formulas? It isn't possible to link simple text?PROVA TABELLA 2.dwg PROVA TABELLA 2.dwg Quote
itacad Posted March 20, 2019 Author Posted March 20, 2019 Hello again! I managed to "link" the cells of a table linked to excel with the attributes of a block through the data fields. I would like to know if there is a way to make an "indirect" connection between the attributes and the table cells. In the example I attach I highlighted the line of the triangle "A" ... is it possible to change the links automatically by switching to the triangle "B" or "C"? thank you in advanceattributi celle tabella.zip Quote
BluePelican Posted April 11, 2020 Posted April 11, 2020 On 3/21/2019 at 3:17 AM, itacad said: Hello again! I managed to "link" the cells of a table linked to excel with the attributes of a block through the data fields. I would like to know if there is a way to make an "indirect" connection between the attributes and the table cells. mybkexperience In the example I attach I highlighted the line of the triangle "A" ... is it possible to change the links automatically by switching to the triangle "B" or "C"? thank you in advanceattributi celle tabella.zip Many thanks for that complete information! Quote
