Shablab
Rename Layout Lisp
Shablab
I have the following Lisp routine below. My problem is that for sheets after 10 the layout that would be named 'SH 02' gets put behind 'SH 10' instead of the initial "SH 01". I'm wondering what I can change to stop this from happening.  I know it's the way autocad/ most programs reads numbers.
(defun c:renamelayouts (/ laylist c)
(setq laylist (vl-sort (layoutlist) '<) c 1)
(foreach x laylist
(command "layout" "R" x (strcat "SH " (if (< (strlen (itoa c)) 2) (strcat "0" (itoa c)) (itoa c)) ""));pad layout names
(setq c (1+ c))
Share this post
Link to post
Tharwat
This?
(if (< c 10) (strcat "0" (itoa c)) (itoa c))
Share this post
Link to post
Lee Mac
The issue is caused by your initial sort:
Since your layout names are not prefixed with leading zeroes at this stage, the layouts are sorted alphabetically, causing the issue you have described.
Share this post
Link to post
BIGAL
A hint to add 0 at front
 (if ( > num 9)
      (setq newnum (strcat "D" (rtos num 2 0)))
      (setq newnum (strcat "D0" (rtos num 2 0)))
      (vla-put-name lay newnum)
Share this post
Link to post
Lee Mac
 (if ( > num 9)
The code is already doing this as part of the rename operation - the issue occurs due to the sort performed before renaming.
Edited by Lee Mac
Share this post
Link to post
BIGAL
Thanks lee.
Share this post
Link to post
ILoveMadoka
After all these observations and comments could someone please post what the final code should look like?
I thought that I could cob the code pieces together but I was wrong...
Please?
Share this post
Link to post
ronjonp
Please?
Here is a quick example with some comments. Perhaps you can learn from it :)
(defun c:foo (/ a i l p x)
  ;; Get layouts
  (vlax-for x (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))) (setq l (cons x l)))
  ;; Sort by taborder and remove model tab
  (setq l (cdr (vl-sort l '(lambda (a b) (< (vla-get-taborder a) (vla-get-taborder b))))))
  ;; Set counter
  (setq i 0)
  ;; Temporarily number them so we don't get duplicates
  (foreach x l (setq i (1+ i)) (vla-put-name x (strcat "FooTempBazoom_" (itoa i))))
  ;; Set counter
  (setq i 0)
  ;; Get the layout count string length so we can add 0's if needed
  (setq a (strlen (itoa (length l))))
  (foreach x l
    ;; Increment counter
    (setq i (1+ i))
    ;; Reset prefix
    (setq p "")
    ;; Add zeroes to prefix if any
    (repeat (- a (strlen (itoa i))) (setq p (strcat p "0")))
    ;; Change the tab name
    (vla-put-name x (strcat p (itoa i)))
(vl-load-com)
Share this post
Link to post
Lee Mac
This question has been answered many times... here is a similar program.
Share this post
Link to post
ILoveMadoka
Just seeing this...
Thank you Sir..
and to you Lee as well..
Share this post
Link to post
